RSS Generator for files on a Webserver
stit
Post Mon Nov 26, 2012 7:52 pm
Hi all,
i wrote a php script which scans for files on a webserver and makes them available as RSS feed.
So files on webserver can be streamed to the TV over http via "Atom/RSS" section at serviio.
<?php
   header("Content-type: text/xml");
   echo "<?xml version=\"1.0\" encoding=\"ISO-8859-1\" ?>";
<rss version="2.0">
<channel>
    <title>Title</title>
    <link>http://www.domain.com</link>
    <description>Description</description>
    <language>de-de</language>
    <lastBuildDate><?php $now = time(); echo date(r, $now); ?></lastBuildDate>
    <image>
      <url></url>
      <link></link>
    </image>
<?php
function ListFiles($dir)
    if($dh = opendir($dir))
        $files = Array();
        $inner_files = Array();
        while($file = readdir($dh))
            if($file != "." && $file != ".." && $file[0] != '.')
                if(is_dir($dir . "/" . $file))
                    $inner_files = ListFiles($dir . "/" . $file);
                    if(is_array($inner_files)) $files = array_merge($files, $inner_files);
            else
               $directLink = str_replace("/var/www/files", "http://www.domain.com/nameOfDirOnServer", $dir);
               array_push($files, $directLink ."/". $file);
        closedir($dh);
        return $files;
$fileLinks = ListFiles('/var/www/files');
foreach($fileLinks as $url) {
   if(preg_match("/.(avi|mkv|mp4)/",$url))
      $filename = basename($url);
      $dirname = basename(dirname($url));
      $filesize = filesize("/var/www/files/".$dirname."/".$filename);
    <item>
    <title><?php echo $filename; ?></title>
    <link><?php echo $url; ?></link>
    <guid><?php echo $url; ?></guid>
    <description><?php echo $filename; ?></description>
    <pubDate></pubDate>
   <enclosure url="<?php echo $url; ?>" length="<?php echo $filesize; ?>" type="video/mp4" />
    </item>
<?php
</channel>
</rss>
If someone knows how to make RSS feed available with .htacces security instead of public webpages, please tell me.
I tried http://user:password@www.domain.com/files/rss.php but serviio doesnt show up the files.
stit
Post Mon Nov 26, 2012 10:29 pm
Re: RSS Generator for files on a Webserver
stit wrote:I tried http://user:password@www.domain.com/files/rss.php but serviio doesnt show up the files.
It should work. Does it work in a browser?
stit
Post Wed Nov 28, 2012 9:17 pm
Yes in the Browser everything works.
But on the TV the Folder with the name of my RSS Entry won't show up.
If i make the .php file public available without the username:passwort@ it works.
But this is no option for me as i don't want to make my files public available :(.
Hopefully this .htaccess support will be implemented ??
Or what am i doing wrong?
stit
Post Wed Nov 28, 2012 9:43 pm
If the server supports HTTP Basic authentication then it should work. Not sure what .httpaccess does.
stit
Post Sat Dec 01, 2012 10:15 pm
This is the .htaccess i am using.
The type of authentication is Basic, so basic authentication should be enabled.
Options +Indexes
AuthName Login
AuthType Basic
AuthUserFile /var/.htpasswd
require user admin
What can i do for debugging ? Checking if serviio is receiving the feed correctly?
Post Sat Dec 01, 2012 10:27 pm
try to enable detailed log
stit
Post Tue Dec 04, 2012 9:51 pm
Or maybe this is the problem?
DEBUGInfo:
2012-12-04 23:00:13,796 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://www.url.com/dlna/Tiger.avi. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:382)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
... 2 more
Can this filecheck be disabled somehow? Because my tv plays nearly all files and a check is not needed.
Or can i enable serviio to show the files even though the link is not working?
Because the links are only working if i copy the files to the public directory, but the rss feed is generated from a not public directory. I make this to secure my files, and copy them only temporary to the public directory to play them. Because .htacces is not working at the moment.
Post Tue Dec 04, 2012 11:16 pm
this check is mandatory
Return to Plugin development
