[SOLVED] missing sound on many online channels with v1.0
• Page 2 of 2 • 1, 2
I've added this to the Sony 2011 profile and I have audio now from Youtube, TED, HD Trailers but not iPlayer. Its a start of a work around thought it would be good to know why AAC on 2011 doesn't work I suspect a work around is the only way forward.
Re: missing sound on many online channels with v1.0
This works for iplayer, youtube, ted, hd-trailers, everything when added on the onlinetranscoding section of Sony 2011 profile.
Should be this
Can you confirm it still works?
- Code:
<OnlineTranscoding>
<!-- Online AAC video streams miss sound, must transcode to ac3 -->
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="384" forceInheritance="true">
<Matches container="mp4" aCodec="aac" />
<Matches container="flv" vCodec="h264" aCodec="aac" />
<Matches container="applehttp" vCodec="h264" aCodec="aac" />
</OnlineTranscoding>
Petr
Help translate Serviio
Confirmed all working (youtube, iplayer, TED, HDTrailers) thanks
Can you please tell me which line this starts as I cannot find the right part of the code? Or attach the updated profiles.xml
Sent from my GT-I9100 using Tapatalk 2
Add those lines to the Sony 2011 profile, just above the very last line that ends </Profile>.
Sound is still not working on my US KDL-46HX729 (2011). I tried both solutions in the last few posts and neither makes a difference. I'm pretty sure I edited the profiles.xml file correctly, although I'm not 100% confident. A corrected attachment would be appreciated.
- Code:
<OnlineTranscoding>
Thanks a lot! This works perfecty for OnlineTranscoding, but can it be copy-pasted also to the Transcoding element to fix sound for e.g. videos downloaded with the youtube-dl script? It seems to work without any hitches, but I'd just like to know if something else is needed to fix this properly.
Question for Zip / Illico, do we need to raise this via bitbucket for inclusion into the next release ?
Re: [SOLVED] missing sound on many online channels with v1.0
Sorry to dig this up but Sony 2011 offline files with AAC audio don't play using Serviio 1.2. Does a similar line to the online section need to be added to get audio working? I thought this was all fixed but maybe not yet.
Nice bump, Zip suggests the same tip as I figured out for online streams, so it seems =aac rather than vod is the right option.
Anyhow try: viewtopic.php?f=11&t=3662&start=40#p65798 for your offline files.
Note: I appear to have broken ITVplayer though, although everything else now seems to work.
