profile configure for RMVB
Weicheng
Post Wed Nov 28, 2012 12:58 pm
Sorry to bring this up again.
RMVB doesn't seem to be supported by Serviio on windows server 2012 essential. I have been trying to get it work in Serviio, Also i have upgraded FFMPEG.exe, which seems to support the RMVB as RV40. please see the attached FFMPEG output info for my test video.
what I tried is adding a new line
<Matches container="rmvb" vCodec="rv40"
in config profile in one container for ps3 prfile.
<!-- transcode MKV with MPEG2 video, remux into mpeg2ts -->
<!-- transcode AVI with AVC video -->
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" maxVBitrate="20000">
<Matches container="rmvb" vCodec="rv40" />
<Matches container="flv" />
<Matches container="ogg" />
Then I restarted the service, which failed to start with following log,
2012-11-28 23:46:11,983 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-enumeration-valid: Value 'rmvb' is not facet-valid with respect to enumeration '[*, mp4, asf, mpegvideo, mpeg, mpegts, matroska, avi, flv, wtv, ogg, 3gp, rtp, rtsp, applehttp]'. It must be a value from the enumeration.
2012-11-28 23:46:11,983 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
at org.serviio.profile.ProfileManager.parseProfilesFromFile(ProfileManager.java:183)
at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:156)
at org.serviio.MediaServer.main(MediaServer.java:112)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
It seems that the profile manager explicitly excludes the RMVB format from its known enumerations. then I tried to use the "*" to replace the "RMVB". tried to restart the service, then a different error in log,
2012-11-28 23:53:14,859 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-enumeration-valid: Value 'rv40' is not facet-valid with respect to enumeration '[vc1, mpeg4, msmpeg4, mpeg2video, mpeg1video, h264, h263, wmv2, mjpeg, flv, vp6, vp8, theora, dvvideo]'. It must be a value from the enumeration.
2012-11-28 23:53:14,874 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
It looks the profile manager is limiting both the media file extension and media format.
would it be possible to add RMVB and RV10-40 as its enumeration if there is no legal issues? as the FFMPEG is already supporting them.
Weicheng
FFMPEG output capture
Post Wed Nov 28, 2012 1:11 pm
Re: profile configure for RMVB
Real Video is not supported in 1.0.1. It'll be supported in 1.1.
Weicheng
Post Wed Nov 28, 2012 1:37 pm
Hi Petr,
That is great to hear. Do you have any ETA for 1.1 release?
Weicheng
Post Wed Nov 28, 2012 2:01 pm
Before Christmas.
FerTegli
Post Sun Jan 13, 2013 9:02 pm
Hello!
I have similar problem. My smart TV it's a samsung UN46D5500. I updated Serviio to v1.1, but I can't see any rmvb movie in this TV.
In the other side, I can see these rmvb movies in my android cellphone, and mediabrowser in Internet Explorer 9.0 from my PC.
I had selected "Samsung TV / Player (C/D/E-series)" as the profile for my Samsung TV. But when I can see any rmvb movie, TV shows a message "Unsupported Video Codec" (actually it's in spanish so the translation could be different, the original message is "Codec de Video no admitido").
All others formats I have, I can see them OK. My problem is only with rmvb movies.
What's the samsung TV problem?
For technical information, this is ffmpeg -i result:
ffmpeg version N-48731-g7e5c5fa Copyright (c) 2000-2013 the FFmpeg developers
  built on Jan 10 2013 19:47:49 with gcc 4.7.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libg
sm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --e
nable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --e
nable-libspeex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --en
able-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable
-libxavs --enable-libxvid --enable-zlib --enable-filter=frei0r
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.107 / 54. 59.107
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
  libpostproc    52.  2.100 / 52.  2.100
[rm @ 02e41a20] Invalid stream index 2 for index at pos 388989766
Input #0, rm, from 'test.rmvb':
    title           :
    author          :
    copyright       :
    comment         :
    ASMRuleBook     : #($Bandwidth >= 0),Stream0Bandwidth = 64082, Stream1Bandwi
dth = 435918;
    Audiences       : Easy RealMedia Tool's Audience;
    audioMode       : music
    Creation Date   : 12/2/2008 1:38:00
    Description     : This File is Created by Easy RealMedia Tools@!
    Email           : rick@redcheek.net
    Generated By    : Easy RealMedia Tools V1.8x
    HomeWeb         : http://redcheek.net
    Keywords        :
    Modification Date: 12/2/2008 1:38:00
    videoMode       : normal
  Duration: 01:42:21.21, start: 0.000000, bitrate: 506 kb/s
    Stream #0:0: Audio: cook (cook / 0x6B6F6F63), 44100 Hz, stereo, fltp, 64 kb/
s
    Stream #0:1: Video: rv40 (RV40 / 0x30345652), yuv420p, 704x288, 434 kb/s, 30
 fps, 30 tbr, 1k tbn, 1k tbc
Post Mon Jan 14, 2013 4:42 pm
can you post detailed log of playing the file?
Users browsing this forum: Baidu [Spider] and 47 guests
