Samsung E-Series, "No Supported File Format"
smue
Post Thu Nov 29, 2012 6:23 am
Good Morning,
since yesterday i'm using serviio, but i have problems that i can't solve by myself.
My TV is a Samsung UE46ES6760. I have installed serviio and i setup the profiletype to 'Samsung C,E.. Series'.
Converting is activated. The file Formats of my Films are (mkv, avi, m2ts), but no Film Works. I tried to deactivate converting and i chose another type of Profile but it didn't worked. My Firmware is up to date.
Thank you
Regards
smue
csholmq
Post Thu Nov 29, 2012 8:24 am
Re: Samsung E-Series, "No Supported File Format"
Enable detailed logging. Then post the log.
smue
Post Thu Nov 29, 2012 11:10 am
how can I activate the detailed logging?
Her is a little part of the current log.
The message on my Samsung is every Time "Wrong File Format...."
2012-11-29 12:04:43,512 INFO [WebServer] WebServer shutting down
2012-11-29 12:04:43,513 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-11-29 12:04:43,513 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-11-29 12:04:43,513 INFO [EventDispatcher] Leaving EventDispatcher
2012-11-29 12:04:43,513 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-11-29 12:04:44,738 INFO [LibraryAdditionsCheckerThread] Added file '00093.MTS' (title: The Stream) to Library
2012-11-29 12:04:46,172 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-11-29 12:04:47,295 INFO [RendererSearchSender] Searching for Renderer devices
2012-11-29 12:04:47,295 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-11-29 12:04:47,300 INFO [WebServer] WebServer starting on port 8895
2012-11-29 12:04:47,301 INFO [EventDispatcher] Starting EventDispatcher
2012-11-29 12:04:47,302 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-11-29 12:04:47,763 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth7 (VMware Virtual Ethernet Adapter for VMnet8) and address 192.168.17.1, timeout = 0
2012-11-29 12:04:49,337 INFO [LibraryAdditionsCheckerThread] Added file '00094.MTS' (title: The Stream) to Library
2012-11-29 12:04:58,338 INFO [LibraryAdditionsCheckerThread] Added file '00095.MTS' (title: The Stream) to Library
2012-11-29 12:05:01,460 INFO [LibraryAdditionsCheckerThread] Added file '00096.MTS' (title: The Stream) to Library
2012-11-29 12:05:19,286 INFO [LibraryAdditionsCheckerThread] Added file '00097.MTS' (title: The Stream) to Library
2012-11-29 12:05:23,909 INFO [LibraryAdditionsCheckerThread] Added file '00098.MTS' (title: The Stream) to Library
2012-11-29 12:05:28,343 INFO [LibraryAdditionsCheckerThread] Added file '00099.MTS' (title: The Stream) to Library
2012-11-29 12:05:36,816 INFO [LibraryAdditionsCheckerThread] Added file '00100.MTS' (title: The Stream) to Library
2012-11-29 12:05:44,926 INFO [LibraryAdditionsCheckerThread] Added file '00101.MTS' (title: The Stream) to Library
2012-11-29 12:05:52,147 INFO [LibraryAdditionsCheckerThread] Added file '00102.MTS' (title: The Stream) to Library
2012-11-29 12:06:04,081 INFO [LibraryAdditionsCheckerThread] Added file '00103.MTS' (title: The Stream) to Library
2012-11-29 12:06:14,639 INFO [LibraryAdditionsCheckerThread] Added file '00104.MTS' (title: The Stream) to Library
2012-11-29 12:06:17,606 INFO [LibraryAdditionsCheckerThread] Added file '00105.MTS' (title: The Stream) to Library
2012-11-29 12:06:22,167 INFO [LibraryAdditionsCheckerThread] Added file '00106.MTS' (title: The Stream) to Library
Thank You,
Best regards
smue
csholmq
Post Thu Nov 29, 2012 11:27 am
smue
Post Fri Nov 30, 2012 8:28 am
Good morning,
yesterday I changend the conf into DEBUG mode, but i think i've solved the problem otherwise.
I saw in the log strange IP addresses, for example 192.168.17.1. My net address is 192.168.1.xxx, so i deactivated the network controllers from my VMware Workstation.
I restarted the server and it worked. Can that be? Had anyone the same problem?
Best regards
smue
ginjaninja
Post Tue Dec 04, 2012 10:29 am
you can bind serviio to a specific adapter
http://www.serviio.org/component/content/article/10-uncategorised/43-supported-system-properties?highlight=YToxOntpOjA7czo0OiJiaW5kIjt9
http://www.serviio.org/index.php?option=com_content&view=article&id=21#q3
it makes sense that additional adapters could result in serviio not bound to the right adapter (if you dont specify as above)
although how you could browse but not play is not clear to me. (unless serviio binds multiple services to different adapter eg, browsing and playing)?
Users browsing this forum: No registered users and 58 guests
