Java upgrade broke Serviio console
intothevoid
Post Thu Nov 29, 2012 7:27 pm
I've been using Serviio 1.0.1 on Windows 8 x86 for the last week or two and I'm loving it! Well done guys.
Windoze then decided that a java 7 upgrade was needed and now the Serviio console won't load. It says EXE4J_JAVA_HOME cannot be located.
I've removed all java and reinstalled serviio from the original distro which installs java 6 and all is ok again. But this wont last for long as windoze will want to update again some time soon. :evil:
Any idea what to look for when this happens next time?
thx
Post Thu Nov 29, 2012 9:49 pm
Re: Java upgrade broke Serviio console
You should be able to disable automatic updates in Java preferences (Control Panel)
intothevoid
Post Thu Nov 29, 2012 10:08 pm
True, but I'd rather keep java patched and up to date, than pinned at a point in time.
Post Thu Nov 29, 2012 11:06 pm
Then it might occur that the console breaks.
Users browsing this forum: No registered users and 63 guests
