serviidb.com
Post Thu Sep 27, 2012 8:29 pm
Re: serviidb.com
How is the be site responding? Is it faster? Have you tried the serviio mediabrowser on there?
Post Sun Oct 07, 2012 5:09 pm
Re: serviidb.com
Would anyone be interested in a serviidb.com twitter feed?
Post Wed Oct 10, 2012 4:18 am
Re: serviidb.com
I have setup the website so after you have created the 1st entry for a media you can "Clone" it and only have to change only the fields that have to change for any other media that have most of the same fields. Usually these are Title, Description and Media-url. By doing this it is very easy to add content to the server. I did this for the ABC plugin and added 8 media entries in 10 minutes.
Post Fri Nov 02, 2012 3:33 pm
Re: serviidb.com
I added a poll to my site to see what way people would like to handle translations on the site. I am leaning more toward using google translate to translate the site to the requested language, this will make it easier to post and maintain the website, since there would only be one copy of each post.
Post Wed Nov 14, 2012 1:21 pm
Re: serviidb.com
I have started using github to control the API code. Feel free to look around it and post any issues or requests for the API there. I will be adding more to the WIki soon.
https://github.com/moltra/serviidb
Post Fri Nov 16, 2012 8:39 pm
Re: serviidb.com
I made a couple of small fixes to the serviidb.com/apidev/ restful resource. Please make sure not there affects your apps so I can copy it to the main api. I am going to add version control to the api next so that you can test it when you want to and when no one is using an older rev, I can remove it. it will be controlled by a APIrev parameter.
Please let me know if you see any problems with the apidev.
Post Sat Nov 17, 2012 9:20 am
Re: serviidb.com
Apears to work the same from some limited testing.
Post Sun Nov 18, 2012 7:36 pm
Re: serviidb.com
I added a couple of API related content on my site. You can see how many times serviidb API has been accessed by your program and see what the most often requested search terms are.
Post Tue Nov 20, 2012 7:28 pm
Re: serviidb.com
I can also make special reports / pages that will only show information from at the API for a specific client for the developer's use.
Xmantium
Post Sat Dec 01, 2012 4:58 pm
Re: serviidb.com
I'll add all the plugins to the site, leave the adult one out for now
To make it easy for Will and other ServiiDB intergrators, i'll rename them close to the API name
Will is it ok to use your media icons for ServiiDroid?
Moltra i remember you had the Plugin list at the side that displayed the table for each plugin
Think it will be cool if we had http://thetvdb.com/ link for TV shows too, this way will be quick for third party tool to collect images for tv shows
Post Sat Dec 01, 2012 5:25 pm
Re: serviidb.com
I will see what i can do about the tv shows.
I am also worKing on a media system content type. That will allow users to enter their media system info and display most used items.
Xmantium
Post Sat Dec 01, 2012 5:33 pm
Re: serviidb.com
Everytime i try to navigate to another section it logs me out, SU or normal user, could it be my browser?
Post Sat Dec 01, 2012 5:43 pm
Re: serviidb.com
Not sure. Will was having that problem also. What browser?
Post Sat Dec 01, 2012 9:03 pm
Re: serviidb.com
Can you change iPlayer back to 'iPlayer (UK)' as it's broken the matching that ServiiDroid does.
Which icons did you want?
Post Sat Dec 01, 2012 9:15 pm
Re: serviidb.com
I thought i had changed it back already.
Xmantium
Post Sat Dec 01, 2012 10:43 pm
Re: serviidb.com
im using Chrome
ive added 2 plugins but its not listed here - http://www.serviidb.com/plugins
Nor is iPlayer there
Post Sat Dec 01, 2012 11:07 pm
Re: serviidb.com
I am 100 miles from home. When i get home tonight i will look. Having trouble with my iPad wifi.
Xmantium
Post Sun Dec 02, 2012 12:07 am
Re: serviidb.com
will wrote:Which icons did you want?
Video, Image and Music - Think would be cool if its all the same icons so theres more harmony amongst various Serviio tools
Post Sun Dec 02, 2012 9:51 am
Re: serviidb.com
Xmantium wrote:im using Chrome
I made some changes to the plugin views. See how it works now. I also added an "Edit Plugin" page which is a different setup for the same data.
Post Sun Dec 02, 2012 10:45 am
Re: serviidb.com
Have you changed the API, ServiiDroid isn't getting any results when searching?
