H 264 Stalling and stuttering on Sony Bravia KDL-32EX723
Arkham
Post Thu Nov 29, 2012 3:29 pm
Hi Guys
I'm terribly sorry if this has been answered anywhere before but I'm having trouble viewing H 264 mkv files on the Sony (it plays x263 great though)
It's running off a wired connection and it's a Mac pro with 8GB Ram and 2x2.66 GHz cores.
Is this just a 'machine can't handle the transcoding' issue or something quite common that can be fixed?
Again, apologies, I don't really understand the majority of the working of this 'dark art' ;)
Cheers
Arkham
Post Thu Nov 29, 2012 3:49 pm
Re: H 264 Stalling and stuttering on Sony Bravia KDL-32EX723
ere's some more info:
  built on Jul 10 2012 22:12:54 with gcc 4.0.1 (Apple Inc. build 5493)
  configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
Input #0, matroska,webm, from '/*********************************************** - S01E01 - 720p WEB DL DD5 1 H 264.mkv':
    creation_time   : 2012-10-05 00:58:44
  Duration: 00:22:29.09, start: 0.000000, bitrate: 4593 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 2k tbc (default) (forced)
      title           : Video
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default) (forced)
      title           : English 5.1
Post Thu Nov 29, 2012 7:46 pm
Could you try to "pause" wait some minutes (wait of temp transcoding file ended), then "resume" and check if video stuttered?
Arkham
Post Thu Nov 29, 2012 9:57 pm
Really? I'll give that a go thanks!
Arkham
Post Sun Dec 02, 2012 5:44 pm
Ok, I gave it a go, but it still did exaclty the same thing.
Has to be a profile problem right?
Or like I said, the server isn't fast enough to transcode and transmit? (wired network BTW)
Post Sun Dec 02, 2012 7:08 pm
Run the tool in this thread. viewtopic.php?t=2439 your wifi might be fighting for time slices.
Arkham
Post Mon Dec 03, 2012 8:59 am
Even though the TV and terminal are Wired?
Anyhows, I tried to run that SSID tool before I realised it's windows only ;)
