[Solved]Samsung TV can not find Serviio
Incom
Post Sun Dec 02, 2012 9:54 pm
I apologize in case I have missed something that is blatantly obvious.
But I read the "read before posting", I read the FAQ, I searched for a similar post and yet I am still having my issue.
I have a Samsung C-series TV I am trying to stream content to wirelessly through a D-link DIR-645 router from a stationary PC.
The TV is finding the network and connecting ok.
The PC running serviio v1.0.1 evaluation copy finds and shows the TV in the DLNA list.
I bound the serviio to recognize 192.168.0.100 as the serviio source (the PCs IP).
Serviio has added and shared two folders containing a whole bunch of different video files.
The TV does however not show me "serviio" as one of the devices it can access. It only shows my computer.
I went and made inbound and outbound rules for my windows 7 firewall to allow TCP port 8895 and UDP port 1900.
I made similar routing for the router for the IP 192.168.0.101 (the TVs IP).
I still can not display the device serviio.
Changing source to DLNA only tries to access some folder on my comuter, not the folders shared by serviio.
I have found a DLNA section in my router settings. For some reason I am not allowed to alter any settings in this configuration and I have mailed d-link about this.
My hope is however that you know of something else I might have overlooked that I could rectify.
I have added my log for your reference.
Thankful for any solution to my problem.
serviio error.log
(395.68 KiB) Downloaded 530 times
csholmq
Post Sun Dec 02, 2012 11:03 pm
Re: Samsung TV can not find Serviio
It almost sounds like you have some other DLNA server running on your computer. That could be the conflict.
Post Sun Dec 02, 2012 11:06 pm
Look in your router settings look for a dlna or qos setting and change it to the opposite it is now and restart router
Incom
Post Mon Dec 03, 2012 6:35 am
Not sure which one did it, but one of the many small tweaks I made must have been right since now serviio shows up on my TV.
Thanks for your time guys. If I figure out exactly which parameter solved it, I will update the thread with that info.
Users browsing this forum: Google [Bot] and 48 guests
