Upgrade to 1.0.1 from 0.62
fixitchris
Post Fri Oct 05, 2012 1:58 pm
I just upgraded my config to 1.0.1, opened up mediabrowser and HOLY CRAP!!!! This is awesome! Paid my $25 for PRO... I would have paid $50 ;)
Thanks for the awesome product.
-chris
Post Fri Oct 05, 2012 4:14 pm
Re: Upgrade to 1.0.1 from 0.62
Glad you like it :-)
smithoid
Post Sun Dec 02, 2012 5:19 am
I have been using ver 0.5.2 successfully, but have been unable to get either 0.6.2 or 1.0.1 to work correctly. My computer (Mac) recognises the TV (green dot). My TV recognises the wireless router, but not the Serviio server (when ver 0.6.2 and 1.0.1 running). Any tips appreciated. :?:
Post Sun Dec 02, 2012 7:03 am
Can you post the serviio.log file from 1.0.1
smithoid
Post Mon Dec 03, 2012 5:10 am
Thanks for your response. Where do I find the serviio log file, and can I copy and paste it?
Post Mon Dec 03, 2012 10:43 am
smithoid wrote:Thanks for your response. Where do I find the serviio log file, and can I copy and paste it?
Look at the Support forum, read READ ME BEFORE POSTING and create a new thread there. Thanks.
smithoid
Post Mon Dec 03, 2012 8:10 pm
Thank you for your interjection, which I did not find particularly helpful. I am a non-technical person, and I picked what I thought was the most appropriate thread pertaining to the problem I am experiencing. I had already looked at how to find the log file, and the instructions didn't mean a lot to me. I was hoping for a bit more "hand-holding" help from a sympathetic user. If you want me to start a new thread, please suggest a topic and category and I would be happy to oblige.
Post Mon Dec 03, 2012 9:28 pm
create a thread here: viewforum.php?f=5
Return to User experiences
