streaming desk top to tv
Kyle0815
Post Wed Dec 05, 2012 1:34 pm
Re: streaming desk top to tv
is there a reason why the howto uses these direct show filters, instead of the screen capture source "screen://" that comes with vlc?
I've been experimenting shortly with the vlc desktop streaming and can't get serviio to accept my stream. The problem seems to be ffmpeg, it gives me lots of errors when I try ffmpeg -i "http://<my-ip>:<my-port>". However, when I open this url in vlc on another computer in my network, it shows the stream just fine. I am running win7 64bit, serviio 1.0.1, vlc 2.0.4 with the following command:
vlc -vvv screen:// :screen-fps=24.000:sout=#transcode{vcodec=h264,vb=1000,scale=1,acodec=mpga,ab=128,channels=2,samplerate=44100}:http{mux=ts,dst=:8080/} :sout-keep
The ffmpeg that came with serviio1.0.1 says:
c:\Program Files\Serviio\lib>ffmpeg -i "http://<my-ip>:<my-port>"
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pkg-config
[h264 @ 0441A160] non-existing PPS referenced
[h264 @ 0441A160] non-existing PPS 0 referenced
[h264 @ 0441A160] decode_slice_header error
[h264 @ 0441A160] no frame!
The 4 last lines are repeated over and over again. As said, the stream plays in vlc on another machine. Would greatly appreciate any hint!
Bye, Kyle.
Post Wed Dec 05, 2012 7:36 pm
Yes because the process works with them if you follow the process explicitly which includes using vlc 1.1.10 and transcoding to MPEG2video
Also ffmpeg -i http://localhost:8081 will then display the mpeg2 stream parameters.
Of course you are welcome to beat your brains out developing your own process. Who knows, you might be the first one to succeed!
henny
Post Mon Jan 21, 2013 10:08 pm
Hey There, I can pick up stream from TV but picture is shocking, I can barely make out the image, its all grey with black lines through it ( I duplicated the output in my bat file and took a screen shot and uploaded it)
I've tried every single bat file that people have posted on here and they all give me the same result
however, When i use the Gui interface, open capture device -> stream -> options -> and paste the the bat file in "stream output string" and click stream the stream i get a good image in vlc.
Running:
VLC 1.1.10
VACGD
SCR
OS: win7 enterprise 32-bit (6.1,build 7601)
Model: Satellite Pro s500
Processor: intel(R) CORE(TM) i5 CPU M 520 @2.40GHz (4CPUs), ~2.4GHz
Memory: 4096MB RAM
DirectX 11
IM using the bat file from wiki
@echo off
:This bat is used to stream the desktop with VLC using HTTP
:A corresponding player must be started using HTTP
"C:\Program Files\VideoLAN\VLC\vlc.exe" -vvv dshow:// --sout=#transcode{venc=ffmpeg,vcodec=mp2v,vb=10000,fps=24,scale=0.5,width=1280,acodec=mp3,ab=192,channels=2,samplerate=44100}:std{access=http,mux=ts,dst=:8081} --no-sout-rtp-sap --no-sout-standard-sap --ttl=1 --sout-keep :dshow-vdev=screen-capture-recorder :dshow-adev=virtual-audio-capturer :dshow-caching=2000
:Exit
MY ffmpeg
"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "http://192.168.x.x:8081"
C:\Users\Educator>"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "http://192.168.x.x:8081"
g-config
http://192.168.x.x:8081: Input/output error
I Dont think its a problem with my TV coz as i said, when i add the Duplicate code to the bat it still does it.
Any suggestions?
image blurry.gif (170.28 KiB) Viewed 27008 times
Post Tue Jan 22, 2013 2:53 am
Try changing the screen resolution of your display to 1280x720 before running the bat.
henny
Post Tue Jan 22, 2013 5:58 am
jhb50 wrote:Try changing the screen resolution of your display to 1280x720 before running the bat.
YAHHHH YOUR MY HERO
Fixed the problem. thank you very much
henny
Post Tue Jan 22, 2013 6:21 am
One quick question, this doesn't use any of my monthly data does it?
For instance, If i was to stream a power point presentation to my TV, this would not use any of my monthly data would it? as I'm not using the internet?
Post Tue Jan 22, 2013 2:13 pm
Right.
henny
Post Wed Jan 23, 2013 4:29 am
During a 2 hour stream of my desktop to tv i encountered 20 iregular 2sec stops (im guessing buffer) iregular in that i had maybe 8 stops in 15mins and then none for 30mins.
Is this normal? sre their any tips or tricks to prevent this?
Secondly, about every 30mins the audio was noticbly infront of the video (e.g the actors words in the movie were behind there lip movement) - i had to stop the stream and re open.
I'm not sure wether the stops(buffers?) have anything to do with the video falling behind the audio, but again any tips or tricks to help fix this problem would be great.
THANKS again for your guys help
Post Wed Jan 23, 2013 5:26 am
Dependent on your cpu. I have no similar problems with 8core I7 but if you have an older 2 core system it may not be able to keep up.
yogevk
Post Thu Feb 07, 2013 3:25 pm
Hey, with your help I've managed to stream my DVB-T card with vlc and serviio to my smart-TV and to my xtreamer side-winder.
i get video and audio on my smart-TV but my xtreamer only gets video.
this is what i'v enterd in VLC:
sout=#transcode{venc=ffmpeg,vcodec=mp2v,vb=10000,fps=24,scale=0.5,width=1280,samplerate=44100}:std{access=http,mux=ts,dst=:8081} --no-sout-rtp-sap --no-sout-standard-sap --ttl=1 --sout-keep
I've removed this:
acodec="aac",ab=64,channels=2
because it's the only way i get audio on my smart-TV. even if add those option i don't get audio on my xtreamer.
i don't need it to work in the TV, it was just for check.but i need audio in my xtreamer.
can you help me?
Post Thu Feb 07, 2013 5:06 pm
You need to find out what codecs xstreamer will play..ac3, mp3,flac etc then get vlc to encode to it.
yogevk
Post Thu Feb 07, 2013 5:37 pm
jhb50 wrote:You need to find out what codecs xstreamer will play..ac3, mp3,flac etc then get vlc to encode to it.
this is from their website:
Media files supported
Video containers:
MPEG1/2/4 Elementary (M1V, M2V, M4V)
MPEG1/2 PS (M2P, MPG)
MPEG2 Transport Stream (TS, TP, TRP, M2T, M2TS, MTS)
VOB
AVI, ASF, WMV
Matroska (MKV)
AVC HD
MOV (H.264), MP4, RMP4
FLV - Flash Video
Video codecs:
Audio containers:
AAC, M4A
MPEG audio (MP1, MP2, MP3, MPA)
WAV
WMA
FLAC
OGG
RMP4
FLC
PCM
PLSX
Audio codecs:
Audio Down Mix : DTS-HD MA, DTS-HD HR
Photo formats : JPEG, BMP, PNG, GIF, HD JPEG
Other formats: ISO, IFO, FLV, RM, RA, RAM
Subtitle formats : SRT, SMI, SUB, SSA, IDX
Streaming formats : RTSP, FLV
i've tried mp3 and aac and it didn't worked.
Post Thu Feb 07, 2013 10:29 pm
I can only suggest you try others that VLC also supports.
suldi15
Post Mon Feb 11, 2013 6:00 pm
i could not work it out
Post Mon Feb 11, 2013 6:19 pm
This is your first post. What could you not work out?
suldi15
Post Mon Feb 18, 2013 4:04 pm
i managed to stream it to my tv but it its in a negative effect and the size is small and it is streaming late
Post Mon Feb 18, 2013 4:19 pm
Sounds like you did not follow the instructions exactly.
suldi15
Post Sat Feb 23, 2013 3:45 pm
i got the video right but when i select it on my tv it says audio format not supported but i'm using mp3
danprice86
Post Tue Jul 09, 2013 5:37 am
Can anyone assist me?
I am having problems making the Bat file run. I have installed all necessary video/audio recorders, they are listed in VLC etc.
I am running the below Bat, as per the wiki, with the exe location and the audio device amended. All I get is a repeating command line in command prompt, that is: C:\Program Files (x86)\VideoLAN\VLC>StreamDesktop.bat (it just flashes and repeats over and over v quickly). I have tried adding .exe after the VLC location and the same thing happens (not sure if it should be there or not?). VLC does not launch.
The bat file is not word wrapped.
StreamDesktop.bat
@echo off
"C:\Program Files (x86)\VideoLAN\VLC" -vvv dshow:// --sout=#transcode
:Exit
Post Tue Jul 09, 2013 12:44 pm
Why is your prompt set to C:\Program Files (x86)\VideoLAN\VLC>
and where is StreamDesktop.bat located?
My prompt is the windows default of C:\Users\John>
and I start it with C:\BAT\streamdesktop.bat
Return to General discussion
