Web UI in Ajax (Mobile & desktop edition)
qoolbox
Post Sat Dec 01, 2012 8:34 am
Re: Web UI in Ajax (Mobile & desktop edition)
kairoh wrote:what is your licence? is it expired?
Hi Kairoh,
I didnt put any licence,
just put the file in my module from Serviio backend and yours (in plugins directory), and make my start init to launch Serviio on Thecus (based on you launch script).
all run fine, just this big bug... :(
I did a the PHP version also, and i dont have problem to run serviio with this frontend
Third Party Thecus NAS Develloper
http://forum.thecus.com
http://www.tsuga.fr
Swehawk
Post Wed Dec 05, 2012 7:55 pm
Swehawk wrote:Any chance that the win service problem is fixed in 1.0.1-a?
*holding my thumbs*
Just wanted to say that I just successfully installed 1.0.1-c as a windows service on win7-32 :D
Had to do it from an elevated cmd prompt. I know I tried that last time with 0.6.2-something with no luck, had all sorts of trouble. Have no idea what made it work this time, and don't care either ;)
Awesome!
jshg46
Post Wed Dec 05, 2012 8:06 pm
I dont have a license, but it still gives me an error on the add resource page.
thenamelessthing
Post Fri Dec 14, 2012 4:28 am
Hi, I have a encoding character problem in the "Presentation" menu. See picture below:
How can I fix this?
Thanks you...
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
raulfg3
Post Fri Dec 14, 2012 3:15 pm
same problem here:
UTF8 problem
error UTF8.jpg (60.49 KiB) Viewed 34273 times
I use ISO 8859-1 not UTF(, and I can't change easily. It's posible to instruct serviio to use ISO 8859-1 instead of UTF8?
Swehawk
Post Fri Dec 14, 2012 5:12 pm
jshg46 wrote:I dont have a license, but it still gives me an error on the add resource page.
+1 When I try to add a web-resource I get : "Error: data.accessGroupIds is undefined.".However, I can add the same web-resource using the original console. I do not have a pro license.
thenamelessthing wrote:Hi, I have a encoding character problem in the "Presentation" menu.....
+1 My lang setting is Swedish, and those buttons look the same.
raulfg3
Post Sun Dec 16, 2012 10:26 am
thenamelessthing wrote:Hi, I have a encoding character problem in the "Presentation" menu. See picture below:
How can I fix this?
Thanks you...
I have the same problem using Firefox, but works fine with Google Chrome.
Please try to use chrome and check if works.
thenamelessthing
Post Sun Dec 16, 2012 2:53 pm
I confirm in Chrome it's okay. But not in firefox..
Swehawk
Post Sun Dec 16, 2012 5:05 pm
Yes, the character encoding is OK in Chrome!
raulfg3
Post Sun Dec 16, 2012 9:25 pm
so it's not a problem of serviio web gui, it's a Firefox problem.
Swehawk
Post Mon Dec 17, 2012 5:24 pm
raulfg3 wrote:so it's not a problem of serviio web gui, it's a Firefox problem.
I doesn't work with IE either, so one out of three is not so good ;) Anyway, it's not a big deal!
Post Mon Dec 17, 2012 7:30 pm
What if you change Character encoding to UTF-8 in the browser?
raulfg3
Post Mon Dec 17, 2012 7:55 pm
I use UTF-8 by default on Firefox and show incorrect characters.
utf-8 used on Firefox
qoolbox
Post Mon Dec 17, 2012 8:21 pm
that is same for me, with Firefox, only Chrome is ok...
I sent some debug info to Kairoh, but still no news since 2 weeks... He must be very busy
http://www.tsuga.fr
thenamelessthing
Post Fri Dec 28, 2012 5:17 am
Hi, since I upgraded to the 1.1 version. The profile list is empty in the webui. How can I fix this?
How can I change the link to the mediabrowser in the remote tab? Actually it redirect to localhost:23424/mediabrowser and I want to redirect to the lan ip interface...
And by the way, how work the "Set up content protection rules" in the webui?
abubin
Post Fri Dec 28, 2012 4:25 pm
I am also seeing those strange characters
nomanbabber
Post Fri Jan 04, 2013 12:52 pm
keep up the good work Great work.
Swehawk
Post Fri Jan 25, 2013 4:50 pm
Wonder if kairoh has abandoned us :? Or maybe just away on a loooong vacation....
weird69
Post Sat Feb 09, 2013 11:38 am
Hi, first of all congrats for the good work.
I'm experiencing some issues tryining to use the webui installed on a Nas4Free Server into a jail.
When i install serviio together with the webui, everything works perfectly. Problem comes when i reboot the server, then i am unable to access the webui console through http://serverip:8123/serviio/console it just says it can't find the web
this is the log i get:
2013-02-09 12:29:49,140 INFO  [RestletProxy] Starting WebUI
2013-02-09 12:29:49,154 INFO  [RestletProxy] Starting Serviio WebUI on port 8123
2013-02-09 12:29:49,177 INFO  [RestletProxy] Another WebUI instance is already started.
2013-02-09 12:29:49,209 INFO  [MediaServer] ------------------------------------------------------------------------
2013-02-09 12:29:49,209 INFO  [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-02-09 12:29:49,210 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-02-09 12:29:49,210 INFO  [MediaServer] http://www.serviio.org
I think it's the second line interrupting the process of starting the webui.
This is the script i use to start it:
#!/bin/sh
##  Serviio start Script                                                    ##
SERVIIO_HOME=/usr/local/etc/serviio-1.1
SERVIIO_CLASS_PATH="$SERVIIO_HOME/lib/*:$SERVIIO_HOME/plugins/*:$SERVIIO_HOME/config"
# Find the best max heap size for JAVA ( From kairoh's serviio-webui
# scripts - https://kairo.bitbucket.org/serviio-webui, who references
# Platter's (http://pcloadletter.co.uk/2012/01.15/serviio-syno-paackages
JAVA_MAX_HEAP=512M
RAM=$(dmesg | grep 'real memory'| uniq | awk '{print $4/1048576}')
if [ $RAM -le 128 ]; then
    JAVA_MAX_HEAP=80M
elif [ $RAM -le 256 ]; then
    JAVA_MAX_HEAP=192M
fi
# Setup Serviio specific properties - might not need to specify ffmpeg
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dffmpeg.location=/usr/local/bin/ffmpeg1"
JVM_OPTS="-Xmx${JAVA_MAX_HEAP} -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20"
# A kludge to get the -D... flags to Java, rather than to Serviio itself:
for o in "$@"
do
   case $o in
   -D*)
      JAVA_OPTS="$JAVA_OPTS $o"
   esac
done
# Execute the JVM in the foreground
exec java $JVM_OPTS $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.restui.ServiioWrapper "$@"
#!/bin/sh
# $FreeBSD: ports/net/serviio/files/serviio.in,v 1.2 2012/01/14 08:56:27 dougb Exp $
# PROVIDE: serviio
# REQUIRE: LOGIN
# KEYWORD: shutdown
# Add the following line to /etc/rc.conf[.local] to enable serviio:
# pc5dczc_enable="YES"
. /etc/rc.subr
name=serviio
rcvar=pc5dczc_enable
command=/usr/local/sbin/serviiod
load_rc_config $name
pc5dczc_user=${pc5dczc_user-"dlna"}
command_args=" &"
stop_cmd="$command -stop"
run_rc_command $1
I have to mention that serviio is working perfectly because i can still stream the videos i could select when the webui was working before rebooting the computer.
What could be causing this?
Thanks a lot
simbeav
Post Wed Feb 20, 2013 10:21 am
Weird69,
Have you found a solution for this yet ?
I get exactly the same problem on NAS4FREE. WebUI was fine, rebooted and not can not access it, but Serviio is running - same "Another WebUI instance is already started." message as you in the log as well.
