Can't access Media Browser
seanequalsyes
Post Fri Dec 07, 2012 5:40 am
I just installed Serviio, so I am pretty new to this, but I am having and issue that I can't seem to find any solution for.
I have Serviio installed on a Windows 2008 server in my home. When I try to access the media browser locally on the server via http://localhost:23424, everything comes up fine. But when trying to access it with a different computer on my network via http://(my_server's_IP):23424, I get the following error:
Not Found
The server has not found anything matching the request URI
You can get technical details here.
Please continue your visit at our home page.
Anyone have any ideas? Any help would be greatly appreciated.
Thanks,
Sean
Post Fri Dec 07, 2012 2:10 pm
Re: Can't access Media Browser
can you ping the server's IP?
Make sure the server doesn't have a firewall blocking incoming port 23424
seanequalsyes
Post Sun Dec 09, 2012 4:03 am
Sorry for the delay in response, here's the answers to your questions.
1. I am able to ping the server and access it remotely otherwise.
- I am able to telnet into the serviio port on the server so it is making a connection.
2. The firewall is not blocking traffic to that port. I tried accessing the media browser with the Windows firewall turned off and I still experienced the same issue.
Thanks,
Sean
Post Sun Dec 09, 2012 2:23 pm
Just to clarify, you have /mediabrowser at the end of the URL, right?
Try with /mediabrowser and /mediabrowser/
jpires
Post Mon Dec 10, 2012 12:09 am
Same problem here.
Similar settings. firewall disabled
henco8
Post Thu Oct 09, 2014 6:22 pm
Hi guys
i know its waaayyyy down the line now, but I came accross this post when i set up my serviio tonight. SAME ISSUE!
firewall off, av disabled, port forwarded, i can telnet into port 23424 with my ip, but browser says blocked.
anyone get a solution by any chance? or can someone maybe advise how to troubleshoot?
thanks in advance! :)
