SKYSPORTSPLUS - A SPORTS STREAM WEBRESOURCE
Post Sun Nov 25, 2012 8:14 pm
SkySportsPlus.groovy - A Video Web Resource
This video Webresource groovy is invoked with http://www.skysports.plus and will generate a menu of SkySports, Eurosports UK, ESPN UK, Setanta and up to 12 other available streams as provided by the cricfree.tv site. It is based on and uses code from the cricfreetv groovy which is now obsolete.
The groovy also accesses the cricfree schedule page so that each stream title will display the event name and start time of the next 2 scheduled events for each stream in GMT [Coordinated Universal Time (UTC)]. Note that the day does not display so the event may be for a future day. If "No events are scheduled" or the events have not yet started the stream may still be live with an unannounced program, or the stream may yield an error.
To speed up the plugin, it will now only list channels 1-12 if they have scheduled events. To list all channels including those with no scheduled events use the parameter "noevents=1". Note that the other network feeds will always be displayed since they have contiuous programming.
The plugin also includes a quick refresh feature as described in the wiki at http://wiki.serviio.org/doku.php?id=quick_refresh.
The feature may be disabled using the parameter "genurls=0".
The default implementation with no parameters, will cause a refresh to occur at the console default time.
If the parameter "refresh=nnn" is used, eg:http://www.skysports.plus?refresh=30 , refreshes will occur every nnn minutes if more frequent than the console refresh time.
If the parameter "time=nn" is used, eg:http://www.skysports.plus?time=16 ,
the event times will be adjusted to your local time. Just enter the hour in your timezone when it is midnight in GMT. For example CET=23, EST=19 and PST=16.
The groovy will also generate a "events" icon showing the time of the next scheduled refresh.
Nov 25, 2012 - Version 1
Dec 3, 2012 - Version 2 - Update for revised web formats
Dec 4, 2012 - Version 3 - Improve sched matching and add time parm.
Dec 6, 2012 - Version 4 - Correct sched format and midnight timestamp.
Dec 7, 2012 - Version 5 - Correct parameter error
Dec 8, 2012 - Version 6 - Support new channels sentanta australia and ireland
Dec 8, 2012 - Version 7 - Update for revised web format
Dec 8, 2012 - Version 8 - New liveflash uri
Dec 13, 2012 - Version 9 - Update to work if no schedule found
Dec 16, 2012 - Version 10 - new yycast uri, added channel abreviations
Dec 23, 2012 - Version 11 - Add liveflash, myhdtv and leton support
Dec 25, 2012 - Version 12 - Add "Event" icon if no items found
Dec 31, 2012 - Version 13 - Check Network Availability
Feb 3, 2013 - Version 14 - Support New Channels, Add Quick Refresh, put times first and remove no events channels
Feb 9, 2013 - Version 15 - Enhance Refresh Logic, add sources
Feb 10,2013 - Version 16 - Support source change from CET to GMT
Feb 18,2013 - Version 17 - Add livego Source
Feb 23,2013 - Version 18 - Add ESPN USA
Feb 27,2013 - Version 19 - Add Cast4You Source
Mar 2, 2013 - Version 20 - Add Sky Sports F1
Mar 10,2013 - Version 21 - Increase Extract Timeout to 90 seconds
Mar 14,2013 - Version 22 - Add Castalba and Reyhq Sources
Mar 20,2013 - Version 23 - New Reyhq uri
Apr.18,2013 - Version 24 - Add IPL channel, new sources ezcast and goodcast, new leton uri
SkysportsPlus.groovy
SkySportsPlus.groovy V24 - Apr 19,2013
(45.13 KiB) Downloaded 7905 times
csholmq
Post Mon Nov 26, 2012 9:41 pm
Re: SkySportsPlus - A Sports Stream WebResource
Is it just me or is skysports.plus not available?
Post Mon Nov 26, 2012 10:11 pm
Just checked. SS1 is working fine for me.
csholmq
Post Mon Nov 26, 2012 10:13 pm
I meant the http website itself.
mirchy
Post Tue Nov 27, 2012 1:29 am
csholmq wrote:I meant the http website itself.
NOT AVAILABLE FOR ME..
npuser
Post Tue Nov 27, 2012 2:12 am
Not sure why you guys are fixating in web site url. As author said on the first post - the final links are from cricfree.tv meaning http://www.skysports.plus is an arbitrary url to invoke the plugin.
It worked for me and i am sure works for others as well! Try it with serviio as as the way described by OP.
NPuser
kevinm2k
Post Thu Nov 29, 2012 3:19 pm
ESPN isn't available by the looks of things :(
Anyone know where we can get a hold of that one?
Post Thu Nov 29, 2012 3:59 pm
ESPN works fine for me.
Post Tue Dec 04, 2012 5:21 am
Version 2 posted to support revised web format.
Post Wed Dec 05, 2012 12:28 am
Version 3 posted with new time adjustment parameter so events can be shown in your local time.
anglia73
Post Wed Dec 05, 2012 9:27 pm
Many thanks for this plugin all Ok ;)
Sony KDL32EX403 Sony N200 Pentium 4 3.4ghz XP SP3
sarsonuk
Post Thu Dec 06, 2012 1:47 pm
This is not working again, empty directory
Post Thu Dec 06, 2012 3:41 pm
Version 2 fixed that. Nothing in the latest plugin woulld have caused that.
Version 3 and the Version 4 just posted only corrected the titles to display scheduled times correctly.
anglia73
Post Fri Dec 07, 2012 9:34 am
Version 4 works well useful update . Thanks for your work.
Ref ( empty directory from Sarson UK ), I have a sony KDL-32ex403 tv which does not like the sony tv 2009 profile that will show empty directory but I always use the Sony BD Player / SNP profile that works ok for, directory is populated with correct working mpeg2 files.
No idea why, not bright enough to find out , but it worked on my sons Sony n200 media play so i use that profile all the while on my tv and it got rid of my empty directory problem .
Regards
abhu
Post Fri Dec 07, 2012 5:00 pm
Thanks jhb50, version 4 works correctly showing title and schedule.
Serviio on Win7 32-bit
Sony BDV-E370
Post Fri Dec 07, 2012 8:19 pm
Version 5 posted to correct parameter processing error when both parameters are used.
Post Sat Dec 08, 2012 2:16 am
Version 6 posted to support new channels sentanta australia and ireland
mirchy
Post Sat Dec 08, 2012 7:33 am
anglia73 wrote:Version 4 works well useful update . Thanks for your work.
Regards
Thank you Anglia73, you saved my life....!!
spcurtis81
Post Sat Dec 08, 2012 3:39 pm
Hi, Dropped by for two things. One, to say thanks for this plugin, it works great for me on my PS3 and I apprecate your work. Second thing, is it possible to increase the quality of the stream via a parameter in the latest build? I have a feeling I'd seen other plugins with this capability although I'm not sure where I do this and I was wondering if I could do it with this one?
Cheers,
Steve
Post Sat Dec 08, 2012 5:30 pm
No, the quality is that provided by the source capture at cricfree.
Return to Available plugins
Users browsing this forum: Google [Bot] and 7 guests
