serviio service starts then stops
stevvie
Post Fri Dec 07, 2012 11:21 pm
for some reason my serviio service starts then stops right away. I have tried uninstalling java & Serviio, restarting then reinstalling still doesn't start. I an the only user on windows 7 64 with admin rights. here is my log,
2012-12-07 23:17:45,620 ERROR [ApplicationInstanceManager] Error connecting to local port for single instance notification
2012-12-07 23:17:45,621 ERROR [ApplicationInstanceManager] Invalid argument: connect
java.net.SocketException: Invalid argument: connect
at java.net.TwoStacksPlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at org.serviio.ApplicationInstanceManager.registerInstance(ApplicationInstanceManager.java:105)
at org.serviio.MediaServer.checkForRunningInstances(MediaServer.java:266)
at org.serviio.MediaServer.main(MediaServer.java:98)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
2012-12-07 23:17:45,633 INFO [MediaServer] ------------------------------------------------------------------------
2012-12-07 23:17:45,633 INFO [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-12-07 23:17:45,633 INFO [MediaServer] Petr Nejedly 2009-2012
2012-12-07 23:17:45,633 INFO [MediaServer] http://www.serviio.org
2012-12-07 23:17:45,633 INFO [MediaServer] Java 1.7.0_09-Oracle Corporation
2012-12-07 23:17:45,633 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-12-07 23:17:45,633 INFO [MediaServer] File encoding: windows-1252
2012-12-07 23:17:45,633 INFO [MediaServer] Headless mode enabled: true
2012-12-07 23:17:45,633 INFO [MediaServer] User home dir: C:\
2012-12-07 23:17:45,633 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-12-07 23:17:45,746 INFO [WebServer] Socket buffer set to 65535 bytes
2012-12-07 23:17:45,756 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-12-07 23:17:45,756 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: java.net.SocketException: Invalid argument: JVM_Bind
java.lang.RuntimeException: java.net.SocketException: Invalid argument: JVM_Bind
at org.serviio.restlet.RestletServer.runServer(RestletServer.java:84)
at org.serviio.MediaServer.main(MediaServer.java:105)
Caused by: java.net.SocketException: Invalid argument: JVM_Bind
at java.net.TwoStacksPlainSocketImpl.socketBind(Native Method)
at java.net.AbstractPlainSocketImpl.bind(Unknown Source)
at java.net.TwoStacksPlainSocketImpl.bind(Unknown Source)
at java.net.PlainSocketImpl.bind(Unknown Source)
at java.net.ServerSocket.bind(Unknown Source)
at org.restlet.engine.http.connector.BaseServerHelper.createServerSocket(BaseServerHelper.java:118)
at org.restlet.engine.http.connector.BaseServerHelper.start(BaseServerHelper.java:251)
at org.restlet.engine.http.connector.HttpServerHelper.start(HttpServerHelper.java:69)
at org.restlet.Server.start(Server.java:585)
at org.restlet.Component.startServers(Component.java:601)
at org.restlet.Component.start(Component.java:528)
at org.serviio.restlet.RestletServer.runServer(RestletServer.java:73)
... 7 more
Post Fri Dec 07, 2012 11:44 pm
Re: serviio service starts then stops
Looks like Java doesn't have access to the OS network sockets.... Try turning off your firewall if it helps. Otherwise try lower Java version.
Users browsing this forum: No registered users and 55 guests
