Transcoding Question
Aardvogel
Post Sun Dec 09, 2012 6:07 am
I am trying to debug some required transcoding changes for a profile and an Online Resource (specifically the ABC Iview plugin written by TTGUY)
How to do you get FFMPEG -I info for an Online Resource that includes an Auth field?
I have DEBUG turned on for Logging and can see Process Executor executing the FFMPEG -I but I can see no details regarding the file in the log
Post Sun Dec 09, 2012 6:58 pm
Re: Transcoding Question
you will only see the actual commands in the log, not the output of the command. You'll have to find the command in the log and run it manually
Aardvogel
Post Sun Dec 09, 2012 9:57 pm
Ran the command manually but it gives the following error
E:\Program Files\Serviio\lib>ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/mp4:flas
h/playback/_definst_/upstairsdownstairs_01_02.mp4 app=ondemand?auth=daEdQd2c8bwc
8ccc0ancJdxdjcfdjaldbb_-bqXqx8-8-lnp_rFtpF&aifp=v001 playpath=mp4:flash/playback
/_definst_/upstairsdownstairs_01_02.mp4 swfUrl=http://www.abc.net.au/iview/image
s/iview.jpg swfVfy=1 buffer=100000000"
g-config
rtmp server sent error
rtmp server requested close
rtmp://cp53909.edgefcs.net:1935/mp4:fla ... ownstairs_
01_02.mp4 app=ondemand?auth=daEdQd2c8bwc8ccc0ancJdxdjcfdjaldbb_-bqXqx8-8-lnp_rFt
pF&aifp=v001 playpath=mp4:flash/playback/_definst_/upstairsdownstairs_01_02.mp4
swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1 buffer=100000000: U
nknown error occurred
Aardvogel
Post Wed Dec 12, 2012 11:59 am
Anyone got any idea as to why I am getting the above error from FFMPEG -i?
Post Wed Dec 12, 2012 12:08 pm
Either thr rtmp URL is wrong, or the libRtmp cannot deal with it.
also swfUrl is weird, it should be something.swf, not a jpg.
