file not shown on TV
aka399
Post Fri Dec 07, 2012 3:23 pm
hello again,
I got a tv series correctly shown on tv list but an episode is not listed.
here's a file correctly shown:
daniele@debian:~$ ffmpeg -i  "/media/Dati/TV Shows/aaa.mkv"
ffmpeg version git-2012-11-02-77d89a5 Copyright (c) 2000-2012 the FFmpeg developers
  built on Nov  2 2012 22:25:51 with gcc 4.4.5 (Debian 4.4.5-8)
  configuration: --enable-gpl --enable-libfaac --enable-libfdk-aac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libtheora --enable-libvorbis --enable-libvpx --enable-x11grab --enable-libx264 --enable-nonfree --enable-version3
  libavutil      52.  2.100 / 52.  2.100
  libavcodec     54. 70.100 / 54. 70.100
  libavformat    54. 35.100 / 54. 35.100
  libavdevice    54.  3.100 / 54.  3.100
  libavfilter     3. 21.106 /  3. 21.106
  libswscale      2.  1.102 /  2.  1.102
  libswresample   0. 16.100 /  0. 16.100
  libpostproc    52.  1.100 / 52.  1.100
Input #0, matroska,webm, from '/media/Dati/TV Shows/aaa.mkv':
    title           : aaa.mkv
    creation_time   : 2012-10-30 00:09:21
  Duration: 00:41:21.68, start: 0.000000, bitrate: 5041 kb/s
    Stream #0:0: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 2k tbc (default)
      title           : Video WEB-DL 720p
    Stream #0:1(ita): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default)
      title           : Italiano
    Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s
      title           : English
    Stream #0:3(ita): Subtitle: subrip
      title           : Italiano
    Stream #0:4(eng): Subtitle: subrip
      title           : English
and the one not listed:
daniele@debian:~$ ffmpeg -i   "/media/Dati/TV Shows/bbb.mkv"
Input #0, matroska,webm, from '/media/Dati/TV Shows/bbb.mkv':
    title           : bbb.mkv
    creation_time   : 2012-11-06 01:02:49
  Duration: 00:41:21.89, start: 0.000000, bitrate: 4866 kb/s
      title           : Italiano
      title           : English
      title           : Italiano
      title           : English
I don't see any difference, and you? lookin' for an help
miksa
Post Fri Dec 07, 2012 4:45 pm
Re: file not shown on TV
aka399 wrote:hello again,
you may want to check serviio log with debug level turned on.
- Mike
Post Sun Dec 09, 2012 2:28 pm
Can you see them through the Folders category?
aka399
Post Sun Dec 09, 2012 5:00 pm
yes, in the folder category the file is shown. and played too.
Post Tue Dec 11, 2012 9:25 pm
That would suggest that the metadata for the file have not been found, thus it won't put it into the Series / Movies category. Try to rename the file according to the rules: http://www.serviio.org/index.php?option ... icle&id=12
Return to Panasonic
