Bluray player Samsung BD e5300 and online streaming
mr_assar
Post Fri Nov 30, 2012 7:01 pm
Hello.
I have a Samsung bluray player BD E5300. This player is working with all the files I have on my PC, but it is impossible to view any online streaming content. All I get is that file format is not supported. Serviio is correct because I can view online content in my phone, a Samsung Galaxy s2. Is it possible to use this BD E5300 to view online streaming?
Thanks for any information.
Mr_assar
miksa
Post Sun Dec 09, 2012 11:29 pm
Re: Bluray player Samsung BD e5300 and online streaming
you may want to check on serviio console that client profile was assigned correctly.
- Mike
mr_assar
Post Mon Dec 10, 2012 8:49 pm
I have the Samsung C/D/E - profile for my BD E5300.
oliveirasf
Post Sun Nov 17, 2013 6:52 pm
Hi, I have the same problem. In another samsung device, tv UN46ES6500 and works perfectlly. Did you have sugestions ?
Best Regards !
Sidney
Post Mon Nov 18, 2013 11:26 am
Try different profiles (including the Generic profile) specifically testing your on-line files. If you find one that works, come back with the details.
