Serviio on a RPi ? (Raspberry Pi)
dencon
Post Sat Jun 16, 2012 3:06 pm
Hi everyone,
Received my RPi a few days ago, fired it up with debian squeeze. Normally use microchip PIC series and PicBasicPro Looking for an application for this super cheap credit card sized SDK computer.
Taped onto back of a usb 1TB external drive case?
any thoughts ?
Cheers...
Post Sat Jun 16, 2012 3:47 pm
Re: Serviio on a RPi ? (Raspberry Pi)
Well it should work, but only for things that need no transcoding, also RAM will be an issue I guess.
Anyway should just be a case of downloading the linux package, installing java (e.g. http://www.raspberrypi.org/phpBB3/viewt ... 91&p=92193) and then either get ffmpeg or compile it from source (3.5 hours aparently) example guide is near the bottom of here http://raspi.tv/2012/get_iplayer-full-i ... om-scratch or look on the serviio wiki
Otherwise there may be a cross compiler that you could use to speed up the process. If you do get a new build of ffmpeg compiled (I have no idea what is in the repo), then hold onto it, and do write up a post/guide about how you set it up, and what the performance was like.
patters
Post Sun Jul 01, 2012 8:08 am
3.5 hours?! I thought the Pi was supposed to be half decent. The ARM SoC in my Synology NAS compiles FFmpeg in about 25mins.
Post Sun Jul 01, 2012 8:26 am
Just quoted what I read, they may have gone and compiled every library under the sun for it at the same time. I'm too busy atm otherwise I would have ordered one to play with, maybe once I finish my doctorate. A few of the people I work with have ordered them and at least one has arrived, so I'll ask them what compile time for common stuff is like.
patters
Post Wed Jul 04, 2012 7:01 pm
It looks like Raspberry Pi is an ARMv6 core, compared to most current NAS ARMv5 chips, so although it's clocked slower it is in fact much more powerful hardware. This means it has SIMD instructions which should hugely improve its ability to encode media. However, that assumes that FFmpeg contains the necessary optimizations. I guess this is ever more likely though given the number of tablets and android handsets using ARM cores.
I guess perhaps the speed bottleneck relates to it using an SD card as storage.
mpemberton5
Post Tue Jul 24, 2012 1:23 am
@dencon, have you had any luck running serviio on your Raspberri Pi? I've recently learned of this amazing item and am putting some thought into getting one. Would love to hear your experiences. Thanks!
kappclark
Post Wed Sep 05, 2012 1:50 pm
Here is a complete set of free lessons on building an OS for the RPi
http://www.cl.cam.ac.uk/freshers/raspbe ... orials/os/
kappclark
Post Fri Sep 14, 2012 2:02 pm
Now, you can build a super computer out of these little boards !
http://www.southampton.ac.uk/mediacentr ... uter.shtml
Xmantium
Post Mon Dec 10, 2012 2:23 pm
I just got one today as a birthday gift! :D
Revision B now has 512MB RAM which is the minimum requirement to run Serviio.
mpemberton5
Post Mon Dec 10, 2012 3:24 pm
Xmantium wrote:I just got one today as a birthday gift! :D
Green with envy....
csholmq
Post Mon Dec 10, 2012 4:56 pm
The SoC is a Broadcom BCM2835. This contains an ARM1176JZFS, with floating point, running at 700Mhz, and a Videocore 4 GPU. The GPU is capable of BluRay quality playback, using H.264 at 40MBits/s. It has a fast 3D core accessed using the supplied OpenGL ES2.0 and OpenVG libraries.
My NAS (QNAP TS-219PII) only has 512 MB of RAM and only 380 MB is dedicated to JAVA. I have yet to find that the RAM is my bottleneck. Instead, it's the lack of a FPU that chokes up my ARMv5 (1.6 GHz) processor when transcoding.
Thus, it seems as if Raspberry Pi should handle all this much better. 40 Mbit/s H.264 sounds pretty impressive!
Xmantium
Post Mon Dec 10, 2012 5:16 pm
I've still not managed to install Serviio on it yet, looking through Raspberry Pi forums.
There a lot support to install XBMC but no one has come up with a custom Serviio bare OS image for it. The CPU can be overclocked to 1Ghz
Imagine this connected to your WiFi router directly running Serviio 24/7 without a power hungry PC. Probably the easy way would be install a Linux variant, install Java, Apache for Marks Web UI, and then Serviio but this may use too much RAM. A custom image with bare requirements would be great - Linux experts we need your help!
You have to buy licence keys separately to unlock VC1 and MPEG2 codecs at low prices. But if Serviio transcodes the file, not sure if they are a requirement?
csholmq
Post Tue Dec 11, 2012 12:23 pm
Wouldn't RaspBMC be of interest? You can just install Serviio on top of that and you have a combined Serviio server/XMBC player depending on whether you connect it directly to your TV or not. It even supports AirPlay.
csholmq
Post Tue Dec 11, 2012 5:29 pm
It should be noted, that without GPU support in FFmpeg, this wouldn't work very well.
Edit: It seems as if Raspberry Pi is OpenMax based. In other words, we need to get FFmpeg hooked into OpenMax to get some form of GPU acceleration.
An OpenMax FFmpeg wrapper
Xmantium
Post Wed Dec 12, 2012 8:08 pm
Ive read OpenELEC provides a better solution.
Im thinking installing Debian OS, this way i can run Serviio and SabNZBd on it making the ultimate media server! :)
csholmq
Post Wed Dec 12, 2012 8:11 pm
You're still faced with horrible FFmpeg performance.
Xmantium
Post Wed Dec 12, 2012 8:23 pm
csholmq wrote:You're still faced with horrible FFmpeg performance.
Would be difficult without Debian to install Java otherwise Serviio simply would not work
Oracle has support on the RPi running Debian Sqeeze
Anyone had any luck?
csholmq
Post Wed Dec 12, 2012 9:32 pm
Of course. What I meant was that the Raspberry Pi isn't that capable when you can't use the GPU. Since Serviio relies on FFmpeg, you basically have a 700 MHz CPU doing all the heavy lifting.
NX3
Post Wed Dec 26, 2012 9:51 am
Serviio on RPi, you need to get the right version of Raspbian that supports soft floating point as the main release is hard floating point. Java for RPi as yet doesn't support hard floating point and performance is very poor. Oracle are active with RPi and plan to bring to the platform in 2013 but that won't hlep ffmpeg on a 700mhz cpu (or 1ghz if overclocked officially).
RPi can hardware decode and encode on the fly many formats but you need to use the OMXplayer to get the best performance. So unless Zip rewrites Serviio for RPi to use the hardware encoding then performance won't be great.
MiniDLNA works very well on RPi and good alternative for Serviio.
Serviio on RPi would be really good but a thing issues to resolve the first being Oracle supporting the platform.
grolschie
Post Mon Jan 14, 2013 3:13 am
Heya. How did you get on in the end? Any joy?
Users browsing this forum: Google [Bot] and 6 guests
