HAHASPORT - A DYNAMIC SPORTS STREAMS WEB RESOURCE
Rufus McDufus
Post Sun Nov 18, 2012 5:56 pm
Re: HAHASPORT - A DYNAMIC SPORTS STREAMS WEB RESOURCE
v11 working fine for me now - many thanks!
yaro
Post Sun Nov 18, 2012 9:34 pm
I downloaded serviio 1.01 again. Now everything is working. If you are having problems try downloading serviio again.
Post Thu Dec 13, 2012 2:29 am
Version 12 posted with updated leton url
Post Thu Dec 13, 2012 9:12 pm
Version 13 posted with another new Leton ip.
erteerte1
Post Wed Dec 19, 2012 2:11 pm
I have a problem with this plugin and maybe somebody could help me. The problem is that since one week the CPU is at 100%. I’m sure that it’s because of Hahasport plugin. In the log file you can read about 100 times „An error occured while scanning for online item information, will continue java.io.IOException: Unexpected error while invoking plugin (HaHaSport): The operation took more than 30000 ms and has been cancelled.”
If I delete Hahasport plugin the CPU goes back to 4-5%. Has anybody else this problem? Is it possible to resolve this problem because this is my favourite plugin. Thanks in advance.
Post Thu Dec 20, 2012 5:10 am
It happens to me if there are more than 50 links to parse. Typically on saturday with football. If you have estreams=9, reduce it to lower the number of links to be parsed.
erteerte1
Post Thu Dec 20, 2012 8:20 pm
Thank you for the help. I will try it. For me it's a little bit strange that this CPU problem with estreams9 exists only since about 10 days.
Post Thu Dec 20, 2012 9:05 pm
Version 14 posted limiting parsed streams to 50. This should prevent timeouts from happening.
alfista
Post Fri Dec 21, 2012 8:25 am
Don't know if it's the numer of streams that's really the cause. I only have Motorsports (more or less empty this time of the year) and Other (ordinarily only a handful of streams) and I got the same problem. Other plugins (ilive and myiplayer) have also at times derailed and maxed out the CPU.
Post Fri Dec 21, 2012 1:37 pm
Web resource plugins first attempt to build a list of links. Serviio only allows 30 seconds for this and then times out. If the source url(s) is/are slow or there are too many then the timeout will occur. Serviio however, rather than process any links found before the timeout, and refresh at the next scheduled time, will attempt to refresh immediately, and will continue to refresh until the list of links builds successfully. That's why the cpu goes to 100%. I consider this a design flaw, and so have limited the number of links processed by hahasport to prevent that timeout, but I can do nothing to address timeouts caused by slow links which may occur to any plugin at any time.
erteerte1
Post Fri Dec 21, 2012 9:44 pm
It seems that Hahasport.com doesn't exist anymore. :cry:
Post Fri Dec 21, 2012 10:17 pm
It was there last night, but not there now.
newborn
Post Sun Dec 23, 2012 3:14 pm
Will this plugin work with http://www.stopstream.tv/ which hahasport seemed to broadcast 99% of the time, its got some relation to the other site I think, but I suspect the webformat isn't going to be the same.
Post Sun Dec 23, 2012 8:33 pm
Thanks for the pointer. Let me work on it.
erteerte1
Post Sat Dec 29, 2012 11:10 am
Good news: Hahasport.com is back.
newborn
Post Sat Dec 29, 2012 12:05 pm
Yay. Hope there wasn't too much time put into the other site 'wrapper' :)
Post Mon Dec 31, 2012 1:23 am
Version 15 posted to correct refresh times.
Post Tue Jan 01, 2013 6:35 am
Version 16 posted to check network availability
Post Tue Jan 08, 2013 6:29 am
Version 17 posted with major changes to support new Web format, new Leton & IliveIP's, add hqfooty, frame2, nutjob, castasap and coolsport sources and add timers. Support for the All sports Home page is also added.
Because of the large number of streams available, it is possible that the item extact time will exceed the 30 second Serviio limit and the groovy will fail. To avoid this the groovy stops extracting after 27 seconds and processes the streams extracted to that point.
Return to Available plugins
