PACKAGE: Serviio for ReadyNAS (Intel x86)
yupsolo
Post Mon Nov 26, 2012 3:43 pm
Re: PACKAGE: Serviio 1.0.1 for ReadyNAS (Intel x86)
thx. but nothing specific other than a search?
where is serviio 0.3 when installed? I mean not the hidden .serviio
thx
yupsolo
Post Tue Nov 27, 2012 9:31 pm
got this error log:
2012-11-26 18:41:23,338 WARN [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2012-11-26 18:45:28,712 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-11-26 18:45:35,659 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcod
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-63-4-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:79)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
2012-11-26 18:45:35,742 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcod
thx for any help!
csholmq
Post Tue Nov 27, 2012 10:00 pm
You're missing the important bits. You need to include some lines before the error message.
Also, please use Code-blocks when you include alot of text.
npuser
Post Tue Nov 27, 2012 11:53 pm
That is your issue. You might want to look at wiki for option to recompile ffmpeg with with all required options.
Npuser
yupsolo
Post Wed Nov 28, 2012 12:13 am
thanks all for your help!!
but one question: why this problem? I'm using this ffmpeg package used by koffer!
http://readynasxtras.com/readynas-x86-a ... ffmpeg-x86
npuser
Post Wed Nov 28, 2012 1:38 am
if it was working before then i would say it is permission issue. You might want to delete the temporary serviio folder inside transcoding temp folder and let serviio recreate this with proper permission. Here is a similar issue with other package. http://forum.serviio.org/viewtopic.php?p=50383#p50383
NPuser
csholmq
Post Wed Nov 28, 2012 6:53 am
Or perhaps set -Dffmpeg.location=/path/to/ffmpeg if the default one is wrong.
yupsolo
Post Thu Nov 29, 2012 12:08 am
npuser wrote:if it was working before then i would say it is permission issue. You might want to delete the temporary serviio folder inside transcoding temp folder and let serviio recreate this with proper permission. Here is a similar issue with other package. http://forum.serviio.org/viewtopic.php?p=50383#p50383
NPuser
never worked before...
I'm thinking resetting the device...
koffer
Post Sat Dec 01, 2012 8:41 am
It's a compilation ffmpeg without librtmp in the addon by ReadyNASXtras. I compiled ffmpeg with librtmp successfully on my Ultra 4, and it will be include in next update.
Xmantium wrote:
deedesie wrote:Hi Koffer, just another update, but with the Presentation tab in the webui, making changes and pressing the save button does NOT save the settings. Not sure you can replicate this behaviour?
We had this same problem with QNAP NAS boxes too - here is a solution - viewtopic.php?f=17&t=5330&start=180#p56821
Your ReadyNAS php.ini is defaulted to "On"
Thx a lot! I'll try it.
Same, if this setting will work correctly with ReadyNAS Frontview, this fix will be included in next version.
yupsolo
Post Tue Dec 04, 2012 1:06 am
Re: PACKAGE: Serviio for ReadyNAS (Intel x86)
thanx for your time on this addon!
greatly appreciated!
yupsolo
Post Thu Dec 13, 2012 7:22 pm
any news on the 0.5 package?
thx!
Quinny
Post Fri Dec 14, 2012 5:12 am
Finally had a chance to install this. Thanks for the hard work.
Sadly now cant play any mp4's on any of the Panasonics (which is the old issue had with the earlier version of this software on these forums) from the ReadyNAS. I did have the FFmpeg I got then but installed and re brought as had the bug of not "reading" just a blank folder (same as last time which was annoying having to pay again). Files have now started adding (up to 23000), icons are there but so much just returns "cannot play file" even avi's. Will start Pana Codec debugging this weekend sigh.
To same tv's the current serviio works fine from my pc with mp4, mkv and avi.
Good news is ServiioDroid works fine with this as a ui.
Serviio fan. DLNA to Panasonic VT tvs, QNAP 651 and Synology 916 NAS boxes.
dsuls
Post Tue Mar 26, 2013 12:25 pm
Any news about the new version, which includes the "properly" compiled ffmpeg?
Thanks!
Quinny
Post Wed May 08, 2013 6:12 am
2nd the request. Would love the new version if it happended.
zcftr29
Post Tue Jun 04, 2013 6:54 am
I'm keen to try this out, but the download links in the first post are not working. Any chance these could be re-uploaded? Thanks in advance...
waghornm
Post Mon Jul 14, 2014 5:54 pm
New to Serviio and not a computer expert. Trying to install Serviio on Readynas NV+ to play video on Sony Bravia. Any help would be appreciated.
Previous
