Folders with one video file
dfreadhoff
Post Mon Nov 26, 2012 5:50 pm
Would it be possilbe to remove extra clicks by exposing folders with one video file in it as the video files itself? I have all of my personal videos in their own directory with the cover.jpg in the directory. So right now, the folders have generic folder images and then I have to enter it, then click on the single file contained within it to play it. Thanks!
Post Mon Nov 26, 2012 7:21 pm
Re: Folders with one video file
Won't happen
dfreadhoff
Post Tue Nov 27, 2012 3:08 pm
Seems like a trivial change. It could be configured by a simple check box on the console and left off by default. Is the reluctance political, technical or resource? Thanks, it would just help change my media players from a simple folder browser into a power media platform.
Dylan
nona
Post Fri Dec 14, 2012 6:32 pm
for playing a BMDV movie you have to
1) select "Name of Movie"
2) select "BDMV"
3) select "STREAM"
4) select 000XX.m2ts
Would be great it there would be an option to hide all these folders and only Display "Name of the Movie". Same should be done for DVD movies.
Will this perhaps happen as a "Pro" Feature?
Post Fri Dec 14, 2012 7:21 pm
nona wrote:for playing a BMDV movie you have to
2) select "BDMV"
3) select "STREAM"
Serviio could detect a BD or DVD folder structure and only display .vob or .m2ts files, this is your request ?
Return to Feature requests
Users browsing this forum: Google [Bot] and 34 guests
