Smart Hub TV App
Meelis
Post Sat Dec 15, 2012 11:08 pm
Smart Hub TV App
As i still intrested to get work serviio over internet i got a small idea. Serviio works well in local area network but i cant get it work ower internet.
What i would like to have.... To install serviio to may workplace as server. To home SmartHub tv install some serviio app to connect it with my workplace server where serviio is installed and all the movies are. Then i dont have to hold pc all the time on. I just have to turn on tv and will can watch my movies. Even share them with friends.
Post Sun Dec 16, 2012 12:25 am
Re: Smart Hub TV App
Go to my site and try the demo online media browser see signature for link. it should work anywhere you have a browser that supports flash video.
Meelis
Post Sun Dec 16, 2012 11:46 am
Thrue uweb its working that way. But its not comfortable to use it in tv. Actually i am looking for some app for smart tv like app in android phone. Something similar like Plex app for tv. I tryed that one and they have a problem with that. Its not working. They have some security issue with that.
csholmq
Post Sun Dec 16, 2012 11:59 am
One solution would be to bridge the two LANs via VPN. I tried to get it going for myself but I had trouble to get the SSDP broadcasts routed correctly.
Meelis
Post Sun Dec 16, 2012 2:00 pm
csholmq wrote:One solution would be to bridge the two LANs via VPN. I tried to get it going for myself but I had trouble to get the SSDP broadcasts routed correctly.
I tryed that solution with VPN
viewtopic.php?f=6&t=7104
Cant get it to work. From TV i see only a empty folders. It cant read out the folders context by some reason.
Maybe someone can create it? Here is the link. http://www.samsungdforum.com/
Meelis
Post Sun Dec 16, 2012 8:13 pm
Maybe here some smart serviio user who can make app for a samsung smart tv? Or maybe just a edit a bit android app sutable to samsung smart vt? I would like to do it by myself but i am not familiar with this app stuff at all. :( In that link what i gived are the installation program and emulators to create a app. I hope its not a big job to edit androd app suitable for tv but, yeah... actually i dont know about that. Maybe some app creator can reply here and say how difficult it is to create? :)
Post Sun Dec 16, 2012 9:08 pm
Just had a look, they are basically web apps written in HTML and Javascript, so no where near an Android app* so it would be a complete re-write from the groud up.
*Some Android apps are web apps packaged to look like native apps but are generally rubish with poor performance and limited intergration with OS functionallity and UI.
Meelis
Post Sun Dec 23, 2012 10:16 pm
will wrote:Just had a look, they are basically web apps written in HTML and Javascript, so no where near an Android app* so it would be a complete re-write from the groud up.
Will i see that you wery smart about that app stuff. What you think, how difficult to create app for a samsung tv-s? In samsung site is special soft with virtual tv & visual editor for creating a app for samsung tv-s. You like can test it in live without owning samsung tv. I readed from plex forum that they working on it and they want to relase the own app. I like serviio more and i would like to get a serviio app for tv. Looks those tv-app-s are future. At least with that plex app working server ower internet. With serviio its not working. One idea to create app for a remote access if ports are forwared. Then maybe more people start to buy a pro edition of serviio. (also included me, i have no point for a remote at the moment) Ofcorse those people who like serviio. The main issue why i so desprently want that app is that i hope i can runn serviio finally ower internet. Then i dont have to hold pc on allways. Maybe i can use also one server with friend. We all upload movies to one server and all we can watch the same movies. Just turn on tv, runn the app and wola! If its not much asked then maybe can you have a look and check that samsung softvare for app creating? Please :oops: I dont have no idea how to create a app :(
Program called SDK 3.5.2 and SDK 4.0 Beta
NX3
Post Mon Dec 24, 2012 3:27 pm
So from a central serviio server you want to browse and play content to a device ? If you ignore browsing via the tv (which would seem the easy option) then have you tried skifta ? Its a browse / push app to any networks you make available and join.
Meelis
Post Mon Dec 24, 2012 10:42 pm
NX3 wrote:So from a central serviio server you want to browse and play content to a device ? If you ignore browsing via the tv (which would seem the easy option) then have you tried skifta ? Its a browse / push app to any networks you make available and join.
I tryed now to browse from a tv internet browser a serviio mediabrowser... It cant find it. I think tv dont like 192.168.1.68:23424/mediabrowser/. I mean it not like a numbers. At least i think so. From other pc i can find over network media browser. I tryed also for a short time skifta... I didnt found any solution to connect server to tv over internet. There only different options for a mobile phone. I found 3 options from there. See attached picture...
What i want to get?
My TV >>>>> My router >>>>> INTERNET <<<<< Workplace router <<<<< Serviio Server
NX3
Post Tue Dec 25, 2012 10:32 am
Those pictures don't explain everything Skifta can do, they are just easy basic guides. Anyway, you want to play media from Serviio at work over the internet.
What tv have you got ?
How fast is your works upload and your download ?
Does your work have a fixed ip or dyndns name ?
Have you opened up port 23424 on your works firewall ?
Meelis
Post Tue Dec 25, 2012 1:22 pm
NX3 wrote:Those pictures don't explain everything Skifta can do, they are just easy basic guides. Anyway, you want to play media from Serviio at work over the internet.
What tv have you got ? = Samsung UE46ES7000 (Smart TV) & UE40D5000
How fast is your works upload and your download ? = 40/40 up and down
Does your work have a fixed ip or dyndns name ? = Up to 10 different fixed ip adresses. Also it have a one dyndns name.
Have you opened up port 23424 on your works firewall ? = Ports are forwared in workplace router and home router.
Meelis
Post Tue Dec 25, 2012 3:56 pm
I tryed now to browse serviio mediabrowser over internet from tv. Actually thats working by somehow. But result wasnt not good at all. I dont know whay.
Serviio media browser over internet from tv.jpg (209.71 KiB) Viewed 19284 times
Post Tue Dec 25, 2012 8:28 pm
Looks ok to me.
NX3
Post Tue Dec 25, 2012 9:52 pm
Aye looks fine, what were you expecting?
Sent from my HTC Desire S using Tapatalk 2
Meelis
Post Tue Dec 25, 2012 10:35 pm
I was expecting picture like from local network over dlna. There was no fullscreen option. ( maybe i dont know and it is exist) Picture quality was wery bad. And something wrong with connection i think. Movie didnt runn normaly. It was like downloading (buffering maybe) a bit and then played a fiew seconds and then again the same.... For mobile phone that is maybe good enought. But not for tv. :( . I dont think that something wrong with my connection.
I found one article from swedish forum and this is in english. This is it what i am looking for but its not so easy to made it :)
http://www.techsweden.org/forum/viewtop ... 5&t=224879
Post Tue Dec 25, 2012 11:03 pm
There is Fullscreen button, move the mouse over the player.
The speed mostly depends on the source and it's uplink speed. These are normally quite low for home broadband and you might struggle to stream a full quality movies. You can change the quality on the source Serviio's console.
NX3
Post Wed Dec 26, 2012 9:16 pm
As Zip says, hit the full screen button. Quality issues are transcoding to flash because you want to browse via a web browser. As per the article you mention, if your broadband is fast enought then set a connection between the networks so your tv can just browse and play media directly rather than transcode to flash.
Serviio can do what you want as can any media server, your issues is how you join up your networks. Does your work network server support VPN ? Can you setup a connection to that via your router or PC that can feed your tv ?
Meelis
Post Thu Dec 27, 2012 4:26 pm
zip wrote:There is Fullscreen button, move the mouse over the player.
Ok, i found that button and i got the full screen. I tryed it again and its still too slow. Seems its like downloading the movie and then trying to play it :) Then i tryed with the same settings thrue android and that works well. I think its a some tv browser issue or something like that. I dont belive that issue with my internet connection at home. I have here ip tv and everything works well. Server upload is 40 up and i belive that must be enought. At home i have download only 12. I sended link to my friend who have better connection 100 down and hi teld me that movie also like cutting. Not playing smoothly. Hi was thinking that this is a some flash player issue. Also in the right top coner are watermark.
Meelis
Post Thu Dec 27, 2012 4:31 pm
NX3 wrote:As Zip says, hit the full screen button. Quality issues are transcoding to flash because you want to browse via a web browser. As per the article you mention, if your broadband is fast enought then set a connection between the networks so your tv can just browse and play media directly rather than transcode to flash.
Here what i tryed some time ago.... viewtopic.php?f=6&t=7104 Tv cant find serviio over vpn and serviio cant find tv over vpn. Seems like router still blocking something.
Return to Feature requests
