[SOLVED] Pause Resume Skipping Several Minutes
NX3
Post Sun Dec 16, 2012 10:27 am
I'm playing MKVs transcoded on the fly to AVCs on a Sony 2011 lcd tv. When I pause and then press resume the film normally skips forward a coupld of minutes, is this normal ?
The film is fully transcoded and dumped out by Serviio in a few minutes. I've checked the temp folder and its all done as I send in minutes to a SSD drive.
Post Sun Dec 16, 2012 12:07 pm
Re: Pause Resume Skipping Several Minutes
is it similar to this : https://bitbucket.org/xnejp03/serviio/i ... -bravia-tv
Should be solved with beta 1.1, could you try ?
