XBMC NFO FILES
stylepat
Post Mon Dec 17, 2012 9:59 am
XBMC NFO FILES
first of all, sorry for my really bad english!
Ich had dowload Serviio a few day ago and its absolutely perfect!
But i have a Problem with the Thumbnails of my Movies. I use the NFO Files from XBMC and it works good, but it dont show me the Movie Posters.
Why?
Post Mon Dec 17, 2012 10:57 am
Re: XBMC NFO FILES
What is the file extension of your thumbnails ?
stylepat
Post Mon Dec 17, 2012 11:01 am
Re: XBMC NFO FILES
I hope i'm not an Idiot.
The file extension ist jpg, but i hope it is right that there is a link in the NFO File for the thumbnails. I just exported the nfo files from XBMC and then change the options in the Serviio Consol to "XBMC NFO FILES".
Post Mon Dec 17, 2012 11:05 am
Re: XBMC NFO FILES
In XBMC, you have to choose to export to separate files, you will also be asked if you want to export thumbnails and fanart as well.
For thumbnail file format, .tbn are not supported yet. There is an open ticket : https://bitbucket.org/xnejp03/serviio/i ... thumbnails
If thumbnail are in .jpg, that should work.
What is your device (renderer) model ?
Post Mon Dec 17, 2012 11:07 am
Re: XBMC NFO FILES
stylepat wrote:I just exported the nfo files from XBMC and then change the options in the Serviio Consol to "XBMC NFO FILES".
When you change settings, you have to rescan library an force a refresh.
stylepat
Post Mon Dec 17, 2012 11:14 am
Re: XBMC NFO FILES
Hmm ok, first i sayed yes as XBMC asked me to export thumbnails and fanart but Serviio doesn't show it to me... how can i change it that XBMC export the thumbnails as JPG and not TBN Files?
Users browsing this forum: Google [Bot] and 25 guests
