serviio 0.6 on ubuntu 11.10
Petro026
Post Tue Dec 18, 2012 6:32 pm
About a week ago my serviio server stopped being visible on my network. I previously successfully streamed content to my Google TV and Android Phone. These devices never had an issue seeing the server. Now my server doesn't show up in the list of sources on either device. It's not a connectivity to the server issue since it's pingable and the DLNA server that is provide in a windows 7 laptop I have is visible. I have gone through the troubleshooting wikis to no avail. I am posting my log file which is set to the DEBUG level. Any ideas would be appreciated.
2012-12-18 13:29:40,525 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-12-18 13:29:40,533 INFO [MediaServer] ------------------------------------------------------------------------
2012-12-18 13:29:40,533 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2012-12-18 13:29:40,533 INFO [MediaServer] Petr Nejedly 2009-2011
2012-12-18 13:29:40,533 INFO [MediaServer] http://www.serviio.org
2012-12-18 13:29:40,533 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2012-12-18 13:29:40,533 INFO [MediaServer] OS Linux amd64 3.0.0-16-generic
2012-12-18 13:29:40,533 INFO [MediaServer] File encoding: UTF-8
2012-12-18 13:29:40,533 INFO [MediaServer] Headless mode enabled: true
2012-12-18 13:29:40,533 INFO [MediaServer] User home dir: /root
2012-12-18 13:29:40,533 INFO [MediaServer] Temp dir: /tmp
2012-12-18 13:29:40,619 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-12-18 13:29:40,660 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-12-18 13:29:40,665 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-12-18 13:29:42,509 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-12-18 13:29:42,509 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-12-18 13:29:42,510 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-12-18 13:29:42,511 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-12-18 13:29:42,512 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-12-18 13:29:42,512 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-12-18 13:29:42,513 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-12-18 13:29:42,513 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-12-18 13:29:42,514 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-12-18 13:29:42,753 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-12-18 13:29:42,790 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2012-12-18 13:29:43,197 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-12-18 13:29:43,198 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2012-12-18 13:29:43,396 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-12-18 13:29:43,397 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2012-12-18 13:29:43,510 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2012-12-18 13:29:43,511 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2012-12-18 13:29:43,609 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-12-18 13:29:43,610 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2012-12-18 13:29:43,698 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-12-18 13:29:43,700 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2012-12-18 13:29:43,811 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-12-18 13:29:43,813 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2012-12-18 13:29:44,025 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-12-18 13:29:44,026 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2012-12-18 13:29:44,058 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-12-18 13:29:44,060 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2012-12-18 13:29:44,307 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2012-12-18 13:29:44,308 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2012-12-18 13:29:44,733 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2012-12-18 13:29:44,735 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2012-12-18 13:29:44,906 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-12-18 13:29:44,907 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2012-12-18 13:29:45,054 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-12-18 13:29:45,056 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2012-12-18 13:29:45,104 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-12-18 13:29:45,105 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2012-12-18 13:29:45,135 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-12-18 13:29:45,137 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2012-12-18 13:29:45,218 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-12-18 13:29:45,219 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2012-12-18 13:29:45,252 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-12-18 13:29:45,254 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2012-12-18 13:29:45,331 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-12-18 13:29:45,332 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 19
2012-12-18 13:29:45,606 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2012-12-18 13:29:45,608 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2012-12-18 13:29:45,856 INFO [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2012-12-18 13:29:45,870 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2012-12-18 13:29:45,875 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2012-12-18 13:29:45,877 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2012-12-18 13:29:45,877 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2012-12-18 13:29:45,878 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-12-18 13:29:45,878 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2012-12-18 13:29:45,879 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1355855385878, LastAccessTime = 1355855385878, getTimeToLiveSeconds() = -1, createTime = 1355855385878 ]
2012-12-18 13:29:45,899 INFO [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2012-12-18 13:29:45,899 INFO [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-12-18 13:29:45,899 INFO [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2012-12-18 13:29:45,899 INFO [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-12-18 13:29:45,899 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2012-12-18 13:29:45,900 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2012-12-18 13:29:45,900 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-12-18 13:29:45,900 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2012-12-18 13:29:45,900 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2012-12-18 13:29:45,900 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-12-18 13:29:45,900 INFO [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2012-12-18 13:29:45,900 INFO [CompositeCacheConfigurator] Finished configuration in 24 ms.
2012-12-18 13:29:45,908 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-12-18 13:29:45,926 INFO [WebServer] Socket buffer set to 65535 bytes
2012-12-18 13:29:45,926 INFO [Device] Created UPnP Device with UUID: 5085bec6-9261-31b0-af2a-d6ac387fdc84, bound address: 192.168.1.7
2012-12-18 13:29:45,943 INFO [PluginCompilerThread] Looking for plugins at /root/Downloads/serviio-0.6.0.1/plugins
2012-12-18 13:29:45,943 INFO [PluginCompilerThread] Started looking for plugins
2012-12-18 13:29:45,946 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2012-12-18 13:29:45,948 DEBUG [ProcessExecutor] Starting ffmpeg
2012-12-18 13:29:45,980 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-12-18 13:29:46,004 INFO [WebServer] WebServer starting on port 8895
2012-12-18 13:29:46,008 DEBUG [DiscoveryManager] UPNP device 5085bec6-9261-31b0-af2a-d6ac387fdc84 (192.168.1.7) is available
2012-12-18 13:29:46,013 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-12-18 13:29:46,016 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.1.7, timeout = 0
2012-12-18 13:29:46,016 INFO [EventDispatcher] Starting EventDispatcher
2012-12-18 13:29:46,019 INFO [RendererSearchSender] Searching for Renderer devices
2012-12-18 13:29:46,019 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-12-18 13:29:46,024 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-12-18 13:29:46,025 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (eth0) and address 192.168.1.7, timeout = 0
2012-12-18 13:29:46,036 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2012-12-18 13:29:46,043 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.7:50759
2012-12-18 13:29:46,045 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.7:50759
2012-12-18 13:29:46,069 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.7, timeout = 0
2012-12-18 13:29:46,070 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 5085bec6-9261-31b0-af2a-d6ac387fdc84
2012-12-18 13:29:47,879 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-12-18 13:29:52,043 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2012-12-18 13:29:57,880 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.7, timeout = 0
2012-12-18 13:29:57,883 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 5085bec6-9261-31b0-af2a-d6ac387fdc84
2012-12-18 13:29:59,688 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-12-18 13:30:09,690 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.7, timeout = 0
2012-12-18 13:30:09,692 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 5085bec6-9261-31b0-af2a-d6ac387fdc84
2012-12-18 13:30:11,498 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:06
2012-12-18 13:30:12,046 INFO [FeedUpdaterThread] Started looking for information about online feeds
2012-12-18 13:30:12,061 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-12-18 13:30:12,062 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-12-18 13:30:12,085 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-12-18 13:30:12,100 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-12-18 13:30:12,100 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-12-18 13:30:12,204 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: /root/Videos
2012-12-18 13:30:12,204 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /root/Videos
Petro026
Post Sun Dec 23, 2012 6:43 pm
Re: serviio 0.6 on ubuntu 11.10
Still not working. None of my renderers can see serviio. I really don't have any options left. I also tried the following things.
1)upgraded to 1.0.1 and then 1.1 with the same result
2)tried different versions of java (currently using 7.0_10)
3)added udp port 1900 and tcp port 8895 to router config.
4)verified serviio is listening on port 1900
5)Enabled aVia media server on my droid and all my renderer devices can see that.
I guess the only thing I am left with is taking some tcpdump captures to determine what traffic isn't making it in and/or out. Can anyone provide any tips on what i should look for??
Users browsing this forum: No registered users and 54 guests
