Problem with console on windows
blakituya
Post Thu Dec 20, 2012 1:33 pm
First of all sorry for my english.
I followed the steps described here http://pcloadletter.co.uk/2012/01/25/se ... o-package/
I installed Java SE for Embedded 7 (1.7.10) on my Synology 212j and then installed Serviio 1.0.1. The installation was correct (If i write http://192.168.1.100:23424/mediabrowser/ on my computer I see the login screen of Serviio)
Next, I installed only Serviio Console in Windows 7 (I have installed java 1.7.10 JDK), and changed the file ServiioConsole.exe.vmoptions adding this line
-Dserviio.remoteHost=192.168.1.100
But when i launch the console, no display screen. I see the log and it prints the following:
2012-12-20 14:13:06,119 INFO [ServiioConsole] Starting Serviio Console
2012-12-20 14:13:06,240 INFO [ServiioConsole] Connecting to Serviio REST on 192.168.1.100:23423
2012-12-20 14:13:08,808 INFO [Messages] Loaded console message bundle for locale: en
2012-12-20 14:13:22,759 ERROR [ServiioConsole] Unexpected exception occured: null
at org.serviio.ui.view.swing.PresentationView.initComponents(PresentationView.java:92)
at org.serviio.ui.view.swing.PresentationView.<init>(PresentationView.java:81)
at org.serviio.ui.view.swing.ServiioFrameView.<init>(ServiioFrameView.java:79)
at org.serviio.console.ServiioConsole.main(ServiioConsole.java:106)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2012-12-20 14:13:22,820 INFO [ServiioConsole] Leaving Serviio Console
Any ideas??
Thanks in advances
Regards
Post Thu Dec 20, 2012 3:53 pm
Re: Problem with console on windows
You have console from 1.1, and server 1.0.1 - they are not compatible. You will have to wait for Synology release 1.1, or use a compatible webui/ServiiDroid alternative.
Eyedoctor2
Post Mon Dec 24, 2012 10:37 am
Exact same problem as user above.
Added -Dserviio.remoteHost=192.168.11.162 to ServiioConsole.exe.vmoptions but couldn't figure out (or if I need to) how to edit the file and add the variable to JAVA_OPTS property on serviio.bat.
Can also get to mediabrowser login screen (what's the password?) but can't connect:
I just realized I also have Synology release 1.01. Do you know when 1.1 will be released?
I can't seem to browse to http://192.168.11.162:5000/serviioweb/index.php finish installlation of serviioweb console. Get a not found error from Synology.
Thamks in advance for your help. Really looking forward to getting this up and running.
Xenoc
Post Fri Dec 28, 2012 4:19 am
I had the same issue and was unable to find an official download for the old 1.0.1 windows installer.
I was able to get it here: http://www.digital-digest.com/software/ ... story.html
Which seems to have resolved the issue and allowed me to connect to the DiskStation server/service.
Users browsing this forum: Google [Bot] and 2 guests
