serviio installed on router
missynmax83
Post Sat Dec 22, 2012 2:01 am
not just now but maybe soon wood it be possible if serviio, be a third party downloaded on to routers and run central at the router.plus add ftp server for add web access to serviio
Xmantium
Post Sat Dec 22, 2012 5:08 am
Re: serviio installed on router
Unless the router runs on Linux and allows installion of 3rd party programs, it would be possible. Would need a fast processor to transcode video though.
The other way you can - buy/build a NAS(Network Attached Storage), these are capable to run 24/7. My NAS server sit side to side with my router.
Popular NAS companies are QNAP, Synology, Thecus, ReadyNAS - these NAS's has ready made packages/modules to install Serviio very easily without you trying to compile it yourself, just like the Windows/Mac installers.
Advantage having a NAS, it can hold alot of storage depending on what NAS you buy.
The cheapest option is running Serviio on Raspberry Pi (costs £25/$25) that can be connected to your router.
missynmax83
Post Sat Dec 22, 2012 9:13 am
thanks that wood be the easyer way
NX3
Post Sat Dec 22, 2012 10:10 am
Serviio on raspberry pi, you need to get the version of raspbian that supports java that Serviio requires. I can't remember of the top of my head but standard raspbian won't run jre. Google it, hard v soft floating point raspbian for pi.
Sent from my HTC Desire S using Tapatalk 2
Return to Feature requests
