[SOLVED] Serviio 1.1 vs homestream 1.1
roccop
Post Fri Dec 21, 2012 11:53 pm
can you tell me the differences between the following 2 softwares?
homestream 1.1
http://www.sony.co.uk/hub/1237485339460
I read that homestream is powered by Serviio.
I'm using Sony Tv and I want to know if this software is dedicated to my TV or is just only the same but with different brand...
Post Sat Dec 22, 2012 12:17 am
Re: Serviio 1.1 vs homestream 1.1
It is basically Serviio 0.6.2 without some functionality, branded as a Sony product.
roccop
Post Sat Dec 22, 2012 9:44 am
In your opinion using the last Serviio 1.1 I will not lost some "Sony compatibles"... just only branded?
NX3
Post Sat Dec 22, 2012 10:04 am
Serviio has more functionality than homestream and a tiny bit more compatibility with file formats e.g raw photos but just as compatible with Sony hardware.
Sent from my HTC Desire S using Tapatalk 2
roccop
Post Sun Dec 23, 2012 10:36 am
Thanks Guys!
I already replaced Homestream with your Serviio 1.1 ;)
