serviio 1.0.1 please
johndriscoll
Post Sat Dec 22, 2012 11:45 am
The new version will not stream my mp4s at the correct aspect ratio. The tweaked profile I had which worked I copied into the new profile list but it wont work. Any chance of posting the previous version 1.0.1 please so I can reinstall it. :( I need this for xmas!
johndriscoll
Post Sat Dec 22, 2012 3:39 pm
Re: serviio 1.0.1 please
OK I have found serviio 1.01 on another download site, reinstalled it copied over my tweaked profile and all is OK again. I would like to have the latest version though so any help as to why my profile wont deliver would be helpful. I have uploaded the profile file for you to look at.
TV is the panasonic G30b
profiles.xml
(68.32 KiB) Downloaded 638 times
Post Sat Dec 22, 2012 5:14 pm
Copy just the affected profile, not the whole profiles.xml. I think one of the Samsung profiles is not compatible, but the Vieira profiles should work.
johndriscoll
Post Sat Dec 22, 2012 8:31 pm
I did what you said and great! works OK . I thought I did this before but ......well one minor mistake in the text and .....Oops!
Users browsing this forum: Google [Bot] and 19 guests
