[SOLVED] Unable to play online streams
moose7
Post Sat Dec 22, 2012 11:53 am
No one stream plays on TV via Serviio.
In example, stream passes Serviio test and I got green tick, but it is not playing.
This is my log file:
(7.74 KiB) Downloaded 450 times
Here is my technical metadata "ffmpeg -i":
technical metadata.txt
(2.67 KiB) Downloaded 550 times
Looking forward to your reply.
Post Sat Dec 22, 2012 2:04 pm
Re: Unable to play online streams
You need to submit a DEBUG log. See my signature.
moose7
Post Sat Dec 22, 2012 2:56 pm
Here is my debug file:
(141.35 KiB) Downloaded 450 times
Post Sat Dec 22, 2012 5:30 pm
Your Ffmpeg is not compatible, most likely too old. Compile a new one, there are some instructions on the wiki.
moose7
Post Sun Dec 23, 2012 4:45 pm
Thank you :)
The problem was as you mentioned old or incompatible ffmpeg.
Finally it works.
