SKYSPORTSPLUS - A SPORTS STREAM WEBRESOURCE
blokey
Post Sun Dec 23, 2012 2:57 am
Re: SkySportsPlus - A Sports Stream WebResource
Try the feed in VLC to confirm it has sound, if so it's something in the profile. Try the sony BDP profile and see if that works.
gb3
Post Sun Dec 23, 2012 9:10 pm
Great work re this groovey! Unfortunately SS1 - 3 are not showing up for me at all using the latest version :(
SS4 SS News etc are all there though. Am I doing something stupid?
Also, for me on all the streams the audio is a little it delayed from the video. Its perfectly synced when played through the PC browser tho.
Cheers.
Post Mon Dec 24, 2012 4:59 am
V11 posted to add more source sites.
slyguy42o
Post Sun Dec 30, 2012 5:58 pm
does anyone know why these streams don't work on an xbox 360? Does the online transcoding profile need to be tweaked?
Post Sun Dec 30, 2012 7:13 pm
Streams are normal avc/mp3.flv's so they should work fine with all profiles.
blokey
Post Mon Dec 31, 2012 12:08 am
They don't work properly with the xbox360, this has been discussed. It seems to timeout before the program has a chance to start, you can get it to work, 1 in 10 times if you keep trying it eventually. This seems to particularly happen with the SkySportPlus streams but less so with the Coolsports Stream, though it can happen there too. I would love to play about with the profile for the xbox a bit but I think they are limited with the type of files you can change it into.
Post Mon Dec 31, 2012 12:30 am
Ok, you should pursue this in the XBOX threads where it has been discussed.
blokey
Post Mon Dec 31, 2012 1:07 pm
Will do, thanks for all the good work! :)
Post Tue Jan 01, 2013 6:37 am
Version 12 posted to check network availability
Post Fri Jan 11, 2013 5:18 am
One of the sites used by cricfree to access these streams, hdmytv, has again hiddden its streams, and so when hdmytv is used these streams will be unavailable, so do not ask why you cannot see one or more of the streams.
bobsmo
Post Mon Jan 21, 2013 4:55 pm
Many thanks for this!
quinnicus
Post Sat Jan 26, 2013 8:45 pm
jhb50 wrote:One of the sites used by cricfree to access these streams, hdmytv, has again hiddden its streams, and so when hdmytv is used these streams will be unavailable, so do not ask why you cannot see one or more of the streams.
Am I assuming correctly, that is why I cannot see the Sky Sports 1,2,3,4 streams etc, but some of the other streams display ok?
nicejumper
Post Sun Feb 03, 2013 9:07 pm
Doesnt look like the regular expressions within the groovy plugin is picking up the channel listing from cricfree.tv. I have not channels to select from.
Can you confirm?
Post Mon Feb 04, 2013 4:18 am
Re: SKYSPORTSPLUS - A SPORTS STREAM WEBRESOURCE
Version 14 posted to support new channels and feeds, and display event times first.
This is a major upgrade of the plugin and features a new quick refresh capability as described in the wiki at http://wiki.serviio.org/doku.php?id=quick_refresh. By default the plugin now only displays active streams for which there are scheduled events.
This makes it practical to do refreshes frequently using the refresh parameter and keep the list of items up to date without the overhead of re-extracting the existing items. Refreshes that previously took many minutes are now done in one or two seconds.
dan_t
Post Sun Feb 10, 2013 12:52 am
Not been able to get the hockey channels working for the last few days. CH1, CH2 etc.... SS channels are working fine. I checked their website and the CH channels are definitely streaming.
I can see them listed on the server but I get a File Not Found or Not Playable error on my sony player. Everything worked fine last week.
Any idea's?
Post Sun Feb 10, 2013 5:46 am
Version 15 posted to Enhance refresh logic and support new sources
Post Sun Feb 10, 2013 7:11 pm
Version 16 posted to support source change from CET to GMT
Post Tue Feb 19, 2013 6:47 am
Version 17 posted to support livego source feeds
Post Sun Feb 24, 2013 6:24 am
Posted V18 with ESPN USA and now only Channels 1-10 are skipped if there are no events scheduled. Other network channels always display unless the source feed is inaccessable (eg: hdmytv).
Return to Available plugins
