FF and Rewind , Samsung es6300
peterpm
Post Sun Dec 23, 2012 10:43 am
I have setup Nas4Freee, Jails & serviio = works like charm :-) Thanks for the great software.
However, no matter which file I try I am unable to ff or rewind. My files are mainly .avi
OS: 9.1-RELEASE FreeBSD 9.1-RELEASE #0 r244224M: Fri Dec 14 19:53:48 JST 2012
ffmpeg version 1.0.1 Copyright (c) 2000-2012 the FFmpeg developers
built on Dec 23 2012 05:49:11 with gcc 4.2.1 (GCC) 20070831 patched [FreeBSD]
serviio: 1.0.1(http://download.serviio.org/releases/se ... nux.tar.gz)
Please advise.
Peter
peterpm
Post Sun Dec 23, 2012 10:50 am
Re: FF and Rewind , Samsung es6300
my ffmpeg build options
configuration: --prefix=/usr/local --mandir=/usr/local/man --incdir=/usr/local/include/ffmpeg1 --libdir=/usr/local/lib/ffmpeg1 --shlibdir=/usr/local/lib/ffmpeg1 --datadir=/usr/local/share/ffmpeg1 --build-suffix=1 --progs-suffix=1 --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-pthreads --enable-memalign-hack --disable-libstagefright-h264 --disable-libutvideo --cc=cc --extra-cflags='-msse -I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --disable-libaacplus --disable-indev=alsa --disable-outdev=alsa --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-libass --disable-libcdio --disable-libcelt --enable-libfaac --disable-libfdk-aac --enable-fontconfig --enable-libfreetype --enable-frei0r --enable-gnutls --disable-libgsm --enable-libmp3lame --disable-libbluray --disable-libv4l2 --disable-libmodplug --disable-openal --enable-libopencv --disable-libopenjpeg --disable-libpulse --enable-librtmp --enable libavutil 51. 73.101 / 51. 73.101
peterpm
Post Sun Dec 23, 2012 11:31 am
Sorry, my bad :-) All works like charm - I just needed to use tools menu from the remote and I am able to go to specific time in the movie just like charm :-)
I also find how to use subtitles in non UTF8 format from the same menu :-)
