No audio on MP4 (h264,aac) since upgrade to 1.0.1
Xtream
Post Sun Dec 23, 2012 10:47 am
Hello!
i'm using the Synology Serviio distribution and i've a problem since my upgrade from 1.0 to 1.0.1 (last available version).
When i try to watch an mp4 video (avc/aac), i've no sound anymore on my Panasonic G20 TV (Panasonic Viera (2010) profile). Video is correctly played (execpt sound).
there is probably a profile change since the last version which cause this problem...
here is a ffmpeg -i info on one of the file which have no sound.
c:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Users\Fabrice\synology links\videos\Clips & Live Singles\Divers\PSY - Gangnam style (4 min 12s, 1080p).mp4"
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='
-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pk
g-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Users\Fabrice\synology links\videos\Clips & Live Singles\Divers\PSY - Gangnam style (4 min 12s, 1080p).mp4':
    major_brand     : mp42
    minor_version   : 0
    compatible_brands: isommp42
  Duration: 00:04:12.16, start: 0.000000, bitrate: 5811 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1080, 5617 kb/s, 23.98 fps, 23.98 tbr, 48k tbn, 47.95 tbc
      creation_time   : 1970-01-01 00:00:00
      handler_name    : VideoHandler
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, s16, 192 kb/s
      handler_name    : IsoMedia File Produced by Google, 5-11-2011
here is a maybe more complete dump done with Format Factory
Complete name                    : C:\Users\Fabrice\synology links\videos\Clips & Live Singles\Divers\PSY - Gangnam style (4 min 12s, 1080p).mp4
Format                           : MPEG-4
Format profile                   : Base Media / Version 2
Codec ID                         : mp42
File size                        : 175 MiB
Duration                         : 4mn 12s
Overall bit rate                 : 5 812 Kbps
Encoded date                     : UTC 2012-07-14 07:48:50
Tagged date                      : UTC 2012-07-14 07:48:50
gsst                             : 0
gstd                             : 252306
gssd                             : B400F7664HH1347366018902682
gshh                             : o-o---preferred---orange-par3---v17---lscache7.c.youtube.com
Format profile                   : High@L4.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 1 frame
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 4mn 12s
Bit rate mode                    : Variable
Bit rate                         : 5 617 Kbps
Maximum bit rate                 : 13.6 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.113
Stream size                      : 169 MiB (97%)
Tagged date                      : UTC 2012-07-14 07:48:51
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : 40
Duration                         : 4mn 12s
Bit rate                         : 192 Kbps
Maximum bit rate                 : 201 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 44.1 KHz
Stream size                      : 5.77 MiB (3%)
Title                            : IsoMedia File Produced by Google, 5-11-2011
Encoded date                     : UTC 2012-07-14 07:48:51
slyguy42o
Post Tue Jan 08, 2013 7:06 pm
Re: No audio on MP4 (h264,aac) since upgrade to 1.0.1
I think each upgrade overwrites profiles.xml, did you try restoring a pre-upgrade version of the file? there should be a backup copy in the folder made by the installer.
Xtream
Post Sun Jan 13, 2013 2:08 pm
finally, it was a regression of the 1.0.1 package for synology.
FFMpeg compilation was not efficient on ARM processor. Version 1.1 correct this problem.
Return to Panasonic
