Serviio 1.1 not working
GBorrelli
Post Sun Dec 23, 2012 6:01 am
I installed Serviio 1.1 and now I get a notice that the Serviio service is not started causing Serviio console to be unable to start at which point it exits. I tried re-installing Serviio, JRE(many versions) and system restore. Nothing worked. I currently have JRE 6u38(32 and 64bit) and Serviio 1.1 installed. I cleared the Serviio log and rebooted as to log only what's going on at startup.
Log file
2012-12-22 23:53:38,143 INFO  [ServiioConsole] Starting Serviio Console
2012-12-22 23:53:38,333 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-12-22 23:53:49,768 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2012-12-22 23:53:59,971 WARN  [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-12-22 23:53:59,971 INFO  [Messages] Loaded console message bundle for locale: en
2012-12-22 23:54:01,453 INFO  [ServiioConsole] Leaving Serviio Console
Post Sun Dec 23, 2012 12:56 pm
Re: Serviio 1.1 not working
Can you see the service has started in the Services management?
GBorrelli
Post Sun Dec 23, 2012 9:07 pm
The service is stopped. I was able to force the service to start through services last night at one point but upon starting Serviio Console the service would stop and Serviio Console would not open. Today I cannot start the service and get a 1067 error.
Post Mon Dec 24, 2012 11:49 am
Did you edit .vmoptions file?
GBorrelli
Post Mon Dec 24, 2012 9:13 pm
No.
ServiioConsole.exe.vmoptions has nothing in it
ServiioService.exe.vmoptions only has one entry -Xmx512m
Post Tue Dec 25, 2012 10:46 am
Does it work if you start Serviio using serviio.bat ?
GBorrelli
Post Tue Dec 25, 2012 8:08 pm
No, the service does not start. However, it does, but does not show anywhere and I can start Serviio Console after running Serviio.bat. I double and triple checked, the service is STOPPED, but I am able to start the Serviio Console and access it from my TV and configure it from my PC. This makes no sense at all...
pheggie
Post Tue Dec 25, 2012 10:46 pm
I've installed 1.1 twice both times it doesn't show up on any of my DLNA devices even though it says it's running went back to 1.0.1 both times and it's working good again Windows 7 32 DLNA Xbox360, PS3, Samsung Blu-ray Player.
Post Tue Dec 25, 2012 10:56 pm
GBorrelli wrote:No, the service does not start. However, it does, but does not show anywhere and I can start Serviio Console after running Serviio.bat. I double and triple checked, the service is STOPPED, but I am able to start the Serviio Console and access it from my TV and configure it from my PC. This makes no sense at all...
Serviio.bat is just another way to start the server, other than the service. So when the bat runs, it behaves the same way as if the service would be running.
GBorrelli
Post Wed Dec 26, 2012 3:50 am
Right... so how do I get Serviio to work like it used to? Where I turn my comp on and it starts with Windows. I tried going back to 1.0.1 it was still fucked up.
Post Wed Dec 26, 2012 10:35 am
Is there something useful in the Windows event logs related to the crashed service?
GBorrelli
Post Thu Dec 27, 2012 12:01 am
At startup the only events pertaining to Serviio are the sevice starting and then maybe nanoseconds later it crashes. The following is the details from the Windows event.
- System
  - Provider
   [ Name]  Service Control Manager
   [ Guid]  {555908d1-a6d7-4695-8e1e-26931d2012f4}
   [ EventSourceName]  Service Control Manager
  - EventID 7034
   [ Qualifiers]  49152
   Version 0
   Level 2
   Task 0
   Opcode 0
   Keywords 0x8080000000000000
  - TimeCreated
   [ SystemTime]  2012-12-26T23:53:18.515361700Z
   EventRecordID 18743
   Correlation
  - Execution
   [ ProcessID]  688
   [ ThreadID]  2804
   Channel System
   Computer Rootkit
   Security
- EventData
  param1 Serviio
  param2 1
Post Fri Dec 28, 2012 12:14 am
If you say 1.0.1 used to work and it doesn't nopw either, it seems the problem is with the environment, most likely Java. Not sure how to debug more other than to try a different java version (possibly not the latest).
kpturner
Post Fri Dec 28, 2012 6:54 pm
I had a very similar problem. I am using Serviio server on a Synology NAS and running the console on my Windows 7 PC. Everything worked perfectly with console version 1.0.1, but it kept bugging me to upgrade to 1.1 so I did. Bad move - it simply refused to run. I can see the console start briefly in the task manager - then it disappears. No GUI ever materialises. With my setup, I have to edit the vmoptions to point at the server on my NAS like this:
-Dserviio.remoteHost=xxx.xxx.xxx.xxx
Eventually I just gave up. I uninstalled 1.1 and reinstalled 1.0.1 and the console is working fine again.
It would be handy if the 1.1 version gave some clue as to what the problem is, but I cannot find anything. Nothing in the windows events anyway - I confess I didn't look at the serviio log.
So I think I will stick with 1.0.1 for now.
GBorrelli
Post Sun Dec 30, 2012 2:24 am
I figured it out thanks to ESET not being able to update. Something or someone changed me TEMP and TMP environmental variables. Changed them back to %systemroot%\TEMP and all is well with 1.1 Wish I knew who or what changed that shit...
lemonface
Post Sun Feb 24, 2013 5:13 pm
I'm having a similar issue on Mac OSX 10.8.2. Tried both Java for OS X 2013-001 and Oracle Java 7. Rolling back to 1.0.1 for now. Here' my log, any ideas?
Marker - Feb 24, 2013 11:05:01 AM
2013-02-24 11:05:14,489 INFO [ServiioConsole] Starting Serviio Console
2013-02-24 11:05:14,598 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-02-24 11:05:14,947 INFO [Messages] Loaded console message bundle for locale: en
2013-02-24 11:05:17,372 ERROR [ServiioConsole] Unexpected exception occured: null
at org.serviio.ui.view.swing.PresentationView.initComponents(PresentationView.java:92)
at org.serviio.ui.view.swing.PresentationView.<init>(PresentationView.java:81)
at org.serviio.ui.view.swing.ServiioFrameView.<init>(ServiioFrameView.java:79)
at org.serviio.console.ServiioConsole.main(ServiioConsole.java:106)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at apple.launcher.LaunchRunner.run(LaunchRunner.java:116)
at apple.launcher.LaunchRunner.callMain(LaunchRunner.java:51)
at apple.launcher.JavaApplicationLauncher.launch(JavaApplicationLauncher.java:52)
2013-02-24 11:05:17,374 INFO [ServiioConsole] Leaving Serviio Console
Post Tue Feb 26, 2013 1:50 pm
This looks like you have different version of the console and the server
Users browsing this forum: Baidu [Spider] and 58 guests
