Setting up Serviio on my Synology DS110J NAS
davecas48
Post Sun Dec 26, 2010 5:39 pm
I do hope you are able to help. I have been trying unsuccessfully to get this excellent system up and running on my NAS. I installed jamvm, and then adjusted the serviio.sh to reflect that, and the remote.Host parameter. However, no luck yet...
My serviio.sh:
#!/bin/sh
## Serviio start Script ##
DIRNAME=`dirname $0`
PROGNAME=`basename $0`
# OS specific support (must be 'true' or 'false').
cygwin=false;
darwin=false;
linux=false;
case "`uname`" in
CYGWIN*)
cygwin=true
Darwin*)
darwin=true
Linux)
linux=true
esac
# For Cygwin, ensure paths are in UNIX format before anything is touched
if $cygwin ; then
[ -n "$SERVIIO_HOME" ] &&
SERVIIO_HOME=`cygpath --unix "$SERVIIO_HOME"`
[ -n "$JAVA_HOME" ] &&
JAVA_HOME=`cygpath --unix "$JAVA_HOME"`
fi
# Setup SERVIIO_HOME
if [ "x$SERVIIO_HOME" = "x" ]; then
# get the full path (without any relative bits)
SERVIIO_HOME=`cd $DIRNAME/..; pwd`
fi
export SERVIIO_HOME
# Setup the JVM
if [ "x$JAVA" = "x" ]; then
JAVA="jamvm"
fi
# Setup the classpath
SERVIIO_CLASS_PATH="$SERVIIO_HOME/lib/serviio.jar:$SERVIIO_HOME/lib/derby.jar:$SERVIIO_HOME/lib/jcs.jar:$SERVIIO_HOME/lib/concurrent.jar:$SERVIIO_HOME/lib/freemarker.jar:$SERVIIO_HOME/lib/httpcore.jar:$SERVIIO_HOME/lib/jaudiotagger.jar:$SERVIIO_HOME/lib/jul-to-slf4j.jar:$SERVIIO_HOME/lib/jcl-over-slf4j.jar:$SERVIIO_HOME/lib/log4j.jar:$SERVIIO_HOME/lib/sanselan.jar:$SERVIIO_HOME/lib/slf4j-api.jar:$SERVIIO_HOME/lib/slf4j-log4j12.jar:$SERVIIO_HOME/lib/org.restlet.jar:$SERVIIO_HOME/lib/org.restlet.ext.xstream.jar:$SERVIIO_HOME/lib/xstream.jar:$SERVIIO_HOME/config"
# Setup Serviio specific properties
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dserviio.remoteHost=192.168.1.254"
# For Cygwin, switch paths to Windows format before running java
if $cygwin; then
SERVIIO_HOME=`cygpath --path --windows "$SERVIIO_HOME"`
JAVA_HOME=`cygpath --path --windows "$JAVA_HOME"`
SERVIIO_CLASS_PATH=`cygpath --path --windows "$SERVIIO_CLASS_PATH"`
fi
# Execute the JVM in the foreground
"$JAVA" -Xmx384M $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
and the resultant log...
2010-12-26 17:11:11,050 INFO [MediaServer] ------------------------------------------------------------------------
2010-12-26 17:11:11,178 INFO [MediaServer] Serviio DLNA media streaming server v 0.4.2 (rev. 683706a96104)
2010-12-26 17:11:11,178 INFO [MediaServer] Petr Nejedly 2009-2010
2010-12-26 17:11:11,179 INFO [MediaServer] http://www.serviio.org
2010-12-26 17:11:11,190 INFO [MediaServer]
2010-12-26 17:11:11,191 INFO [MediaServer] Java 1.5.0-GNU Classpath
2010-12-26 17:11:11,193 INFO [MediaServer] OS Linux arm 2.6.32.12
2010-12-26 17:11:11,194 INFO [MediaServer] File encoding: ISO-8859-1
2010-12-26 17:11:11,195 INFO [MediaServer] ------------------------------------------------------------------------
2010-12-26 17:11:15,028 INFO [RestletServer] Starting Restlet server exposed on 192.168.1.254:23423
2010-12-26 17:11:18,010 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2010-12-26 17:11:18,145 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: No driver found for jdbc:derby:db;create=true
at java.sql.DriverManager.getDriver(DriverManager.java:231)
at java.sql.DriverManager.getConnection(DriverManager.java:161)
at java.sql.DriverManager.getConnection(DriverManager.java:204)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:66)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:59)
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:55)
at org.serviio.MediaServer.main(MediaServer.java:95)
2010-12-26 17:11:20,449 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
Any suggestions???
Post Sun Dec 26, 2010 7:24 pm
Re: Setting up Serviio on my Synology DS110J NAS
Your Java VM is version 1.5, not 1.6. That's one problem I can see immediately.
davecas48
Post Sun Dec 26, 2010 9:26 pm
Oh. That is a problem. I can't find a way of installing any higher version of Java. Does that mean I have to forgo Serviio?? Sob!!
Post Sun Dec 26, 2010 9:33 pm
Just quickly googled, would this help? http://www.nslu2-linux.org/wiki/DS101/JavaOnDS101G
davecas48
Post Sun Dec 26, 2010 10:07 pm
thanks for your prompt replies. Unfortunately, the processor in the ds110j is an ARM, not a PPC...
davecas48
Post Mon Jan 03, 2011 7:23 pm
Ok, I'm getting there!! I have now installed Java 1.6, and can get Serviio on the DS100j. However, I haven't gotten the system to work. I can see the Serviio network on my Sony Bravia. I cannot, however, get the console to connect, which means I cannot set up any folders, and so cannot see any of my media.
Also, serviio.sh never completes - it seems to be in a hang.
This is my serviio.log output, if that will help at all - I really need some advice...
2011-01-03 17:35:06,568 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-01-03 17:35:06,629 INFO [MediaServer] ------------------------------------------------------------------------
2011-01-03 17:35:06,630 INFO [MediaServer] Serviio DLNA media streaming server v 0.4.2 (rev. 683706a96104)
2011-01-03 17:35:06,630 INFO [MediaServer] Petr Nejedly 2009-2010
2011-01-03 17:35:06,631 INFO [MediaServer] http://www.serviio.org
2011-01-03 17:35:06,631 INFO [MediaServer] Java 1.6.0_21-Sun Microsystems Inc.
2011-01-03 17:35:06,632 INFO [MediaServer] OS Linux arm 2.6.32.12
2011-01-03 17:35:06,632 INFO [MediaServer] File encoding: US-ASCII
2011-01-03 17:35:06,633 INFO [MediaServer] ------------------------------------------------------------------------
2011-01-03 17:35:07,779 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-01-03 17:35:08,249 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-01-03 17:35:08,316 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-01-03 17:35:23,940 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-01-03 17:35:23,945 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-01-03 17:35:23,957 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-01-03 17:35:23,962 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-01-03 17:35:23,970 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-01-03 17:35:23,985 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-01-03 17:35:27,628 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-01-03 17:35:27,753 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-01-03 17:35:29,954 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-01-03 17:35:29,987 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-01-03 17:35:30,536 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-01-03 17:35:30,553 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-01-03 17:35:31,047 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-01-03 17:35:31,055 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-01-03 17:35:31,890 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-01-03 17:35:31,901 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-01-03 17:35:32,250 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-01-03 17:35:32,259 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-01-03 17:35:32,582 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-01-03 17:35:32,592 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-01-03 17:35:32,946 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-01-03 17:35:32,955 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-01-03 17:35:33,874 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-01-03 17:35:33,886 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-01-03 17:35:34,911 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-01-03 17:35:34,932 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-01-03 17:35:36,065 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-01-03 17:35:36,101 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2011-01-03 17:35:36,120 DEBUG [ProcessExecutor] Starting ffmpeg
2011-01-03 17:35:36,649 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2011-01-03 17:35:36,672 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-01-03 17:35:37,484 INFO [WebServer] WebServer starting on port 8895
2011-01-03 17:35:37,639 INFO [Device] Created UPnP Device with UUID: 010bee5e-af48-3878-a928-347de8dd0d33, bound address: 192.168.1.254
2011-01-03 17:35:39,123 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-01-03 17:35:39,227 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-01-03 17:35:39,260 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-01-03 17:35:39,260 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-01-03 17:35:39,272 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-01-03 17:35:39,294 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-01-03 17:35:39,296 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1294076139295, LastAccessTime = 1294076139295, getTimeToLiveSeconds() = -1, createTime = 1294076139295 ]
2011-01-03 17:35:39,314 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-01-03 17:35:39,427 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-01-03 17:35:39,428 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-01-03 17:35:39,433 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-01-03 17:35:39,433 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-01-03 17:35:39,434 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-01-03 17:35:39,435 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-01-03 17:35:39,435 INFO [CompositeCacheConfigurator] Finished configuration in 185 ms.
2011-01-03 17:35:39,441 DEBUG [DiscoveryManager] UPNP device 010bee5e-af48-3878-a928-347de8dd0d33 is available
2011-01-03 17:35:39,448 INFO [EventDispatcher] Starting EventDispatcher
2011-01-03 17:35:39,451 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-01-03 17:35:39,456 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-01-03 17:35:39,458 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface 192.168.1.254
2011-01-03 17:35:39,500 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface 192.168.1.254
2011-01-03 17:35:39,774 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 010bee5e-af48-3878-a928-347de8dd0d33
2011-01-03 17:35:39,859 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:11:38
2011-01-03 17:35:40,106 DEBUG [WebServer] Incoming connection from /192.168.1.254:49606
2011-01-03 17:35:40,104 DEBUG [WebServer] Incoming connection from /192.168.1.254:49607
2011-01-03 17:35:40,146 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 17:35:40,152 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 17:35:40,375 DEBUG [WebServer] Incoming connection from /192.168.1.50:4876
2011-01-03 17:35:40,378 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Sonos
2011-01-03 17:35:40,922 DEBUG [WebServer] Incoming connection from /192.168.1.69:2901
2011-01-03 17:35:40,926 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Sonos
2011-01-03 17:35:43,221 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 17:35:43,225 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 17:35:43,236 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 17:35:43,245 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 17:35:43,413 DEBUG [WebServer] Incoming connection from /192.168.1.254:49608
2011-01-03 17:35:43,416 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 17:35:43,423 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 17:35:59,505 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-01-03 17:35:59,536 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 17:35:59,600 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-01-03 17:35:59,601 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 17:39:28,183 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.73:64649
2011-01-03 17:39:28,410 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.73:64649
2011-01-03 17:39:28,416 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.73:64649
2011-01-03 17:39:28,426 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2011-01-03 17:39:28,429 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2011-01-03 17:39:28,432 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2011-01-03 17:39:43,919 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.64:54541
2011-01-03 17:39:43,923 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2011-01-03 17:39:43,960 DEBUG [WebServer] Incoming connection from /192.168.1.73:61159
2011-01-03 17:39:43,963 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from UPnP/1.0
2011-01-03 17:39:43,993 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-01-03 17:39:44,089 DEBUG [WebServer] Incoming connection from /192.168.1.73:61160
2011-01-03 17:39:44,092 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-01-03 17:39:44,246 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-01-03 17:39:44,385 DEBUG [WebServer] Incoming connection from /192.168.1.73:61161
2011-01-03 17:39:44,388 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-01-03 17:39:44,637 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-01-03 17:39:44,895 DEBUG [WebServer] Incoming connection from /192.168.1.73:61162
2011-01-03 17:39:44,932 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from UPnP/1.0 DLNADOC/1.50:
2011-01-03 17:39:45,695 DEBUG [WebServer] Incoming connection from /192.168.1.64:51126
2011-01-03 17:39:45,703 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from null
2011-01-03 17:39:45,709 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 17:39:46,365 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-01-03 17:39:46,406 DEBUG [WebServer] Incoming connection from /192.168.1.73:61163
2011-01-03 17:39:46,409 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from UPnP/1.0 DLNADOC/1.50:
2011-01-03 17:39:46,469 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-01-03 17:39:49,338 DEBUG [WebServer] Incoming connection from /192.168.1.73:61164
2011-01-03 17:39:49,341 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largeJPG
2011-01-03 17:39:49,435 DEBUG [WebServer] Incoming connection from /192.168.1.73:61165
2011-01-03 17:39:49,437 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largeJPG
2011-01-03 17:39:49,539 DEBUG [WebServer] Incoming connection from /192.168.1.73:61166
2011-01-03 17:39:49,541 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largeJPG
2011-01-03 17:46:00,035 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 17:47:18,286 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface 192.168.1.254
2011-01-03 17:47:18,318 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 010bee5e-af48-3878-a928-347de8dd0d33
2011-01-03 17:47:18,347 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:11:06
2011-01-03 17:47:18,378 DEBUG [WebServer] Incoming connection from /192.168.1.254:53758
2011-01-03 17:47:18,387 DEBUG [WebServer] Incoming connection from /192.168.1.254:53759
2011-01-03 17:47:18,388 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 17:47:18,409 DEBUG [WebServer] Incoming connection from /192.168.1.73:61262
2011-01-03 17:47:18,411 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 17:47:18,554 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from UPnP/1.0
2011-01-03 17:47:18,634 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 17:47:18,641 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 17:47:18,636 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-01-03 17:47:18,810 DEBUG [WebServer] Incoming connection from /192.168.1.254:53760
2011-01-03 17:47:18,813 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 17:47:18,821 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 17:47:18,896 DEBUG [WebServer] Incoming connection from /192.168.1.73:61263
2011-01-03 17:47:18,899 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-01-03 17:47:18,905 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-01-03 17:47:19,067 DEBUG [WebServer] Incoming connection from /192.168.1.73:61264
2011-01-03 17:47:19,073 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-01-03 17:47:19,078 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-01-03 17:47:19,331 DEBUG [WebServer] Incoming connection from /192.168.1.73:61265
2011-01-03 17:58:24,919 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:11:04
2011-01-03 17:58:25,081 DEBUG [WebServer] Incoming connection from /192.168.1.254:49666
2011-01-03 17:58:25,084 DEBUG [WebServer] Incoming connection from /192.168.1.254:49667
2011-01-03 17:58:25,087 DEBUG [WebServer] Incoming connection from /192.168.1.73:61367
2011-01-03 17:58:25,089 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 17:58:25,091 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 17:58:25,113 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-:1 from address /192.168.1.53:1025
2011-01-03 18:17:55,332 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2011-01-03 18:17:55,335 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2011-01-03 18:21:01,515 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 18:23:05,633 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface 192.168.1.254
2011-01-03 18:23:05,709 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 010bee5e-af48-3878-a928-347de8dd0d33
2011-01-03 18:23:05,738 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:13:23
2011-01-03 18:23:05,774 DEBUG [WebServer] Incoming connection from /192.168.1.254:36457
2011-01-03 18:23:05,776 DEBUG [WebServer] Incoming connection from /192.168.1.254:36456
2011-01-03 18:23:05,863 DEBUG [WebServer] Incoming connection from /192.168.1.73:61598
2011-01-03 18:23:05,864 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 18:23:05,873 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 18:23:05,876 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from UPnP/1.0
2011-01-03 18:23:06,002 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 18:23:06,036 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 18:23:06,064 DEBUG [WebServer] Incoming connection from /192.168.1.254:36458
2011-01-03 18:23:06,070 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-01-03 18:23:06,093 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 18:23:06,129 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 18:23:06,168 DEBUG [WebServer] Incoming connection from /192.168.1.73:61599
2011-01-03 18:23:06,170 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-01-03 18:23:06,177 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-01-03 18:23:06,323 DEBUG [WebServer] Incoming connection from /192.168.1.73:61600
2011-01-03 18:23:06,342 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-01-03 18:23:06,356 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-01-03 18:23:06,691 DEBUG [WebServer] Incoming connection from /192.168.1.73:61601
2011-01-03 18:23:06,695 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from UPnP/1.0 DLNADOC/1.50:
2011-01-03 18:23:06,791 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-01-03 18:23:06,813 DEBUG [WebServer] Incoming connection from /192.168.1.73:61602
2011-01-03 18:23:06,815 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from UPnP/1.0 DLNADOC/1.50:
2011-01-03 18:23:06,857 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-01-03 18:26:01,733 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 18:31:02,015 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 18:36:00,016 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 18:36:02,285 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 18:36:28,918 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface 192.168.1.254
2011-01-03 18:36:28,947 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 010bee5e-af48-3878-a928-347de8dd0d33
2011-01-03 18:36:29,008 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:10:49
2011-01-03 18:36:29,134 DEBUG [WebServer] Incoming connection from /192.168.1.254:36139
2011-01-03 18:36:29,149 DEBUG [WebServer] Incoming connection from /192.168.1.73:61628
2011-01-03 18:36:29,150 DEBUG [WebServer] Incoming connection from /192.168.1.254:36140
2011-01-03 18:36:29,151 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 18:36:29,157 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from UPnP/1.0
2011-01-03 18:36:29,161 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 18:36:29,238 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 18:36:29,261 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-01-03 18:36:29,277 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 18:36:29,285 DEBUG [WebServer] Incoming connection from /192.168.1.254:36141
2011-01-03 18:36:29,325 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 18:36:29,330 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 18:36:29,358 DEBUG [WebServer] Incoming connection from /192.168.1.73:61629
2011-01-03 18:36:29,360 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-01-03 18:36:29,365 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-01-03 18:36:29,508 DEBUG [WebServer] Incoming connection from /192.168.1.73:61630
2011-01-03 18:36:29,510 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-01-03 18:36:29,516 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-01-03 18:36:29,823 DEBUG [WebServer] Incoming connection from /192.168.1.73:61631
2011-01-03 18:36:29,825 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from UPnP/1.0 DLNADOC/1.50:
2011-01-03 18:36:29,945 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-01-03 18:36:29,965 DEBUG [WebServer] Incoming connection from /192.168.1.73:61632
2011-01-03 18:36:29,967 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from UPnP/1.0 DLNADOC/1.50:
2011-01-03 18:36:30,085 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-01-03 18:41:02,296 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 18:46:02,427 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 18:47:18,950 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface 192.168.1.254
2011-01-03 18:47:18,989 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 010bee5e-af48-3878-a928-347de8dd0d33
2011-01-03 18:47:19,010 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:14:23
2011-01-03 18:47:19,046 DEBUG [WebServer] Incoming connection from /192.168.1.254:45386
2011-01-03 18:47:19,095 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 18:47:19,149 DEBUG [WebServer] Incoming connection from /192.168.1.254:45387
2011-01-03 18:47:19,177 DEBUG [WebServer] Incoming connection from /192.168.1.73:61768
2011-01-03 18:47:19,179 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 18:47:19,182 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from UPnP/1.0
2011-01-03 18:47:19,415 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 18:47:19,421 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2011-01-03 18:47:19,457 DEBUG [WebServer] Incoming connection from /192.168.1.254:45388
2011-01-03 18:47:19,461 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 18:47:19,464 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 010bee5e-af48-3878-a928-347de8dd0d33 from Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6
2011-01-03 18:47:19,480 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-01-03 18:47:19,610 DEBUG [WebServer] Incoming connection from /192.168.1.73:61769
2011-01-03 18:47:19,627 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-01-03 18:47:19,632 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-01-03 18:47:19,773 DEBUG [WebServer] Incoming connection from /192.168.1.73:61770
2011-01-03 18:47:19,775 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-01-03 18:47:19,780 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-01-03 18:47:20,051 DEBUG [WebServer] Incoming connection from /192.168.1.73:61771
2011-01-03 18:47:20,053 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from UPnP/1.0 DLNADOC/1.50:
2011-01-03 18:47:20,095 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-01-03 18:47:20,114 DEBUG [WebServer] Incoming connection from /192.168.1.73:61772
2011-01-03 18:47:20,137 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from UPnP/1.0 DLNADOC/1.50:
2011-01-03 18:47:20,183 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-01-03 18:51:03,196 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-01-03 18:53:13,138 DEBUG [ServiioConsole] Initializing Serviio Console
2011-01-03 18:53:13,367 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2011-01-03 18:53:13,391 INFO [ServiioConsole] Starting Serviio Console
2011-01-03 18:53:13,445 DEBUG [SwingHelper] Choosing java look and feel: javax.swing.plaf.metal.MetalLookAndFeel
2011-01-03 18:53:15,223 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-01-03 18:53:28,429 ERROR [ServiioConsole] Unexpected exception occured: null
2011-01-03 18:53:28,565 INFO [ServiioConsole] Leaving Serviio Console
davecas48
Post Mon Jan 03, 2011 9:23 pm
I tried something else:
I am able to rum the Serviio server and console on my Mac. I am unable to run the Server on my NAS, and connect with either the console on the mac or on the NAS. So, I have now tried running the server on my Mac, and connecting with the console on my NAS. It didn't work, and I got the following log file:
2011-01-03 21:12:23,165 DEBUG [ServiioConsole] Initializing Serviio Console
2011-01-03 21:12:23,349 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2011-01-03 21:12:23,362 INFO [ServiioConsole] Starting Serviio Console
2011-01-03 21:12:23,728 DEBUG [SwingHelper] Choosing java look and feel: javax.swing.plaf.metal.MetalLookAndFeel
2011-01-03 21:12:25,089 INFO [ServiioConsole] Connecting to Serviio REST on 192.168.1.51:23423
2011-01-03 21:12:32,981 ERROR [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused
2011-01-03 21:12:35,070 ERROR [ServiioConsole] Unexpected exception occured: null
2011-01-03 21:12:35,071 INFO [ServiioConsole] Leaving Serviio Console
I have added the servio.remoteHost parameter in all places, and it still doesn't get me any further.
Any help really appreciated...
Post Mon Jan 03, 2011 10:21 pm
looks like the port serviio is trying to use is block by your firewall on one of your devices most likely your router :)
davecas48
Post Thu Jan 06, 2011 7:07 pm
Excellent suggestion! I have now managed to get this working, after setting the firewall correctly. Thank you!!
matten
Post Mon Jan 10, 2011 1:40 pm
Hello there.. I also got JAVA installed on my Synology 1010+ today. Is there any way of getting the console to work or doing the library entries manually?
matten
Post Mon Jan 10, 2011 1:52 pm
Ah no... There is an error:
2011-01-10 14:50:19,896 ERROR [ApplicationInstanceManager] Error connecting to local port for single instance notification
2011-01-10 14:50:19,900 ERROR [ApplicationInstanceManager] No route to host
java.net.NoRouteToHostException: No route to host
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at org.serviio.ApplicationInstanceManager.registerInstance(ApplicationInstanceManager.java:105)
at org.serviio.MediaServer.checkForRunningInstances(MediaServer.java:221)
at org.serviio.MediaServer.main(MediaServer.java:85)
2011-01-10 14:50:19,912 INFO [MediaServer] ------------------------------------------------------------------------
2011-01-10 14:50:19,912 INFO [MediaServer] Serviio DLNA media streaming server v 0.4.2 (rev. 683706a96104)
2011-01-10 14:50:19,912 INFO [MediaServer] Petr Nejedly 2009-2010
2011-01-10 14:50:19,912 INFO [MediaServer] http://www.serviio.org
2011-01-10 14:50:19,913 INFO [MediaServer]
2011-01-10 14:50:19,913 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-01-10 14:50:19,913 INFO [MediaServer] OS Linux i386 2.6.32.12
2011-01-10 14:50:19,913 INFO [MediaServer] File encoding: US-ASCII
2011-01-10 14:50:19,913 INFO [MediaServer] ------------------------------------------------------------------------
2011-01-10 14:50:20,205 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-01-10 14:50:20,333 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
What does it mean?
Post Mon Jan 10, 2011 2:40 pm
davecas48 wrote:Excellent suggestion! I have now managed to get this working, after setting the firewall correctly. Thank you!!
your welcome :)
Post Mon Jan 10, 2011 2:43 pm
matten wrote:Ah no... There is an error:
What does it mean?
have you setup the remotehost bits for serviio and opened the correct ports ???
Post Mon Jan 10, 2011 2:45 pm
do you have localhost in your hosts file?
matten
Post Mon Jan 10, 2011 2:53 pm
Yes, localhost is present. I can ping "localhost" also. But I did not setup anything (the question before).
Post Mon Jan 10, 2011 2:56 pm
looks like the error can be ignored, server seems to run. You have to connect the console remotely from a PC, http://www.serviio.org/component/content/article/21#q2
Zek
Post Mon Jan 10, 2011 9:51 pm
matten wrote:Hello there.. I also got JAVA installed on my Synology 1010+ today. Is there any way of getting the console to work or doing the library entries manually?
OK this is pure awesome. I wish it was Friday so I could do this too on my 1010 too! I did order a 2GB DIMM just in case though :) Are you expecting to be able to transcode video on the 1010's Atom CPU or just remuxing and audio transcode?
Cheers,
Zek
Sony Bravia KDL-55NX810 | Serviio 0.5 (rev. 975aa458693c) | Synology DS-1010+
patters
Post Wed Jan 12, 2011 2:44 pm
So guys, does this work ok? I'm tempted to get one of these DS110J NAS units. Back when I used XBMC I used to share all my content from an NSLU2 but it's too feeble to run Java for Serviio. Thing is, I read that the DS110J only has 128MB RAM. Is that really enough?
matten
Post Sat Jan 29, 2011 6:39 pm
I am still trying to get any kind of console working in order to control my serviio running on my DS 1010+. After that I will report if transcoding works.
patters
Post Mon Jan 31, 2011 9:25 am
My DS111 arrives tomorrow, so I'll be getting stuck in soon.
Users browsing this forum: Bing [Bot] and 21 guests
