Plugins... Do they work with the free version?
gpsis
Post Sun Dec 23, 2012 5:15 pm
I have a Sony SMP-N100 Media Player and I am running Serviio 1.1 FREE VERSION on my Win7 Dual Core laptop.
I downloaded a couple plugins, saved them to the plugin folder of Serviio, but my media player states there is no playable files.
I have tried RSS FEED and WEB RESOURCE but neither shows up.
Anyone have any idea where I went wrong?
USA :?:
Regards!
Device: Sony Media Player SMP-N100
Win7 Dual Core 2.9GHz
3GBR
Malwarebytes Anti-Spyware
BitDefender Total Security
Serviio allowed in all security software
Post Sun Dec 23, 2012 5:29 pm
Re: PLUGINS...DO THEY WORK WITH THE FREE VERSION?
Yes plugins are supported by FREE version.
- Download plugins.
- Add link on serviio console.
- Restart serviio service
- You can try to enable detailed loggin (see signature link), and check if online streams are detected and loaded.
gpsis
Post Mon Dec 24, 2012 2:36 am
Re: Plugins... Do they work with the free version?
Thanks Illico, I had not restarted the service...I'll give that a try.
Regards!
3GBR
Post Mon Dec 24, 2012 8:45 am
gpsis wrote:Thanks Illico, I had not restarted the service...I'll give that a try.
In fact, after a plugin download, you have to restart serviio service or reboot for plugin to be compiled and added to serviio service. Is topic solved ?
Post Mon Dec 24, 2012 11:40 am
No need to restart, the plugin should be found and compiled on the fly
Post Mon Dec 24, 2012 12:40 pm
zip wrote:No need to restart, the plugin should be found and compiled on the fly
on the fly ?? just to understand, is it on every save event, refresh event, a time delay or a plugin folder update ?
Post Mon Dec 24, 2012 6:11 pm
It checks for new files and the update date every minute or so.
gpsis
Post Wed Dec 26, 2012 4:17 pm
Thanks guys! Yes the issue has been resolved.
I did not have to reboot, I just STOPPED and STARTED the Serviio service.
Not certain if the time limit as Zip referred to took affect or if it was as Stop/Start of the service that made it work, but its up and online.
Regards!
3GBR
Users browsing this forum: Baidu [Spider] and 21 guests
