BUG 1.1 (same as 1.0.1) no max bit rate and 720p support
robertsearle
Post Tue Dec 25, 2012 6:20 pm
Dropping of max bit rate and 720p. Same bug as fixed with 1.0.1
Profile Changes from 1.0.1
803,808c803,806
<                       <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="10000" targetACodec="ac3" maxHeight="720" aBitrate="320" forceVTranscoding="true" >
<                               <Matches container="*" vCodec="h264" />
<                               <Matches container="matroska" />
<                               <Matches container="mpegts"  />
<                               <Matches container="mp4"  />
<                               <Matches container="avi"  />
>                       <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="320">
>                               <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.1" />
>                               <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.1" />
>                               <Matches container="matroska" vCodec="vp8" />
Old values from 1.0.1
/usr/local/serviio/bin/ffmpeg -i /blue-ray/YYYYYY.mkv -y -threads 4 -copyts -c:v mpeg2video
MISSING: (CAN"T FIGURE OUT HOW TO HIGHLIGHT)           -b:v 10000k -maxrate:v 10000k -bufsize:v 10000k -vf scale=1280:720 -r 24000/1001 -g 15
-c:a ac3 -b:a 320k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-74-10-ORIGINAL.stf
New Values from 1.1
/usr/local/serviio/bin/ffmpeg -fflags +genpts -threads 4 -i   /blue-ray/YYYYYYY.mkv -y -copyts -c:v copy -bsf:v h264_mp4toannexb -c:a ac3 -b:a 320k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-74-10-ORIGINAL.stf
Post Tue Dec 25, 2012 8:25 pm
Re: BUG 1.1 (same as 1.0.1) no max bit rate and 720p support
Not sure what you mean? From your examples the second profile only remixes h264, therefore it uses codec copy rather than transcoding with a bitrate and resolution limit.
robertsearle
Post Tue Dec 25, 2012 10:13 pm
Yep it was a problem with the profile. My bad.
Users browsing this forum: Baidu [Spider] and 22 guests
