High res jpg problem
sydh
Post Mon Dec 17, 2012 12:01 am
I have searched the forum and a few people have had the "over 4096" resolution problem but no one seems to have solved it. I have tried the addition of:
but this has had no effect, and I see a previous member also tried this with no luck.
Is there no way to display high resolution jpgs? With cameras now saving huge file sizes, this problem must surely be a common problem.
Post Mon Dec 17, 2012 12:51 pm
Re: High res jpg problem
what is your device? It works on my C series TV.
sydh
Post Mon Dec 17, 2012 8:37 pm
I have a new UE55ES8000 and my PC is on W7 x64. I use a Nikon D7000 camera so this limitation is a major restriction for me. Thanks for any help you may offer.
Post Tue Dec 18, 2012 10:52 am
Can you view the images via AllShare server?
sydh
Post Thu Dec 20, 2012 11:47 pm
Hi
Yes it is possible to view photos that are over 4600.
Post Sat Dec 22, 2012 12:30 am
Can you post detailed log of trying to display the file?
sydh
Post Sat Dec 22, 2012 10:39 am
I have attached the log but I also now have a bigger problem as you will see. The server will not run. I turned off the Allshare server which made no difference (can they both run together?) and I disabled the firewall and still no luck.
Maybe you can see both problems from the log. Thanks for staying with me on this.
(61.12 KiB) Downloaded 598 times
Post Mon Dec 24, 2012 11:56 am
Your change to profiles.xml broke it. Also enable detailed logging.
sydh
Post Mon Dec 24, 2012 12:47 pm
I thought I only added the extra line for the resolution problem. How do I resolve this? Re-install? I reverted to the original profile which I had saved but it still will not run.
Post Tue Dec 25, 2012 11:01 am
Probably reinstall is the easiest. Just run the installer again.
sydh
Post Wed Dec 26, 2012 1:12 pm
I have installed the latest 1.1 version and it is running again. So...back to where I started. How do I amend the profile to show large jpg's? The last time I tried, I opened the profile in Notepad, added <LimitImageResolution>false</LimitImageResolution>, and then dragged the .txt file into the .xml file and saved, but this is what you say broke it. What did I do wrong? I admit I know little about xml's.
Post Fri Dec 28, 2012 12:39 am
I think there might be something preventing displaying transcoded images on the D series Samsungs via Serviio. Will try to look into it.
