TC-L55ET5: mkv work but no other file type,transcoding probl
thenamelessthing
Post Fri Dec 21, 2012 5:13 pm
Re: TC-L55ET5: mkv work but no other file type,transcoding p
Help! I really want to solve my issue!
If we can solve the issue I will buy the Pro version! ;-)
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Post Tue Dec 25, 2012 10:55 am
Is the video with this problem transcodes? You can check by looking at the detailed log.
thenamelessthing
Post Thu Dec 27, 2012 7:06 am
MM, after a look in the log. On my test I think he doesn't transcode. It's write "Delivering file 'VTS_02_1.VOB' in native format". But I'm not sure my test is with the same file I obtained the issue. For now in this test the sound is okay, but I have "lite" lag in the picture. How can I find what cause the lag? In the log file I doesn't see any error except about: [WebServer] I/O error: Broken pipe.
2012-12-27 01:53:22,857 DEBUG [WebServer] Incoming connection from /192.168.1.134:64020
2012-12-27 01:53:22,858 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2012-12-27 01:53:22,858 DEBUG [ResourceTransportRequestHandler] GET /resource/5727/MEDIA_ITEM/MPEG_PS_NTSC-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.3:8895,Range: bytes=0-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2012-12-27 01:53:22,859 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2012-12-27 01:53:22,859 DEBUG [ResourceDeliveryProcessor] Request for resource 5727 and type 'MEDIA_ITEM' received
2012-12-27 01:53:22,859 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 5727 (local)
2012-12-27 01:53:22,859 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 5727)
2012-12-27 01:53:22,859 DEBUG [VideoDAOImpl] Reading a Video (id = 5727)
2012-12-27 01:53:22,860 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 5727, format MPEG_PS_NTSC and profile Panasonic Viera E/S/ST/VT (2011)
2012-12-27 01:53:22,860 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 5727 (local)
2012-12-27 01:53:22,860 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 5727)
2012-12-27 01:53:22,861 DEBUG [VideoDAOImpl] Reading a Video (id = 5727)
2012-12-27 01:53:22,861 DEBUG [VideoDeliveryEngine] Delivering item '5727' for client 'IPAddress=/192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2012-12-27 01:53:22,862 DEBUG [VideoDeliveryEngine] Delivering file 'VTS_02_1.VOB' in native format
2012-12-27 01:53:22,862 DEBUG [MediaItemDAOImpl] Getting file of media item 5727
2012-12-27 01:53:22,862 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 5727) as read
2012-12-27 01:53:22,868 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
thenamelessthing
Post Fri Dec 28, 2012 5:07 am
I have try with a normal avi file and everything work! I think lag is only caused in vob files..
thenamelessthing
Post Thu Jan 03, 2013 4:34 pm
[SOLVED]TC-L55ET5: mkv work but no other file type,transcodi
Problem solved. But I don't know why! Maybe because I updated to 1.1
Previous
Return to Panasonic
