Panasonic Issues since upgrading to 1.1
texwatson
Post Thu Dec 27, 2012 5:22 pm
Hi everyone, I'm having the following issues since upgrading to 1.1
This issues were NOT evident on 1.0.1. My TV, PC and network settings are exactly the same. Panasonic Viera P50VT50B. Windows 7 PC, wired ethernet.
1. Buffering issue. Video 'hanging' although sound playing fine. TV showing playback error.
2. Aspect Ratio not correct when playing some mkv files - stretching vertically. Ignores any aspect setting via the TV remote.
3. Refusal to play certain types of video file - error message on TV.
4. TV occasionally isn't able to browse the Serviio server - error on TV. Fixed by restarting PC.
Interestingly the issues are not present on my other TV (LED LG).
How to I downgrade my 1.1 back to 1.0.1 until these apparent bugs are fixed?
texwatson
Post Thu Dec 27, 2012 9:42 pm
Re: Panasonic Issues since upgrading to 1.1
Solved issue with aspect ratio, seems to affect 1080p mkv files so far. Changed to Generic Profile, aspect ratio now correct.
Both the Panasonic 2011 and 2012 profiles screwed the aspect up (stretched vertically).
Other issues still not fixed.
Hopefully will see 1.1.1 soon?
Post Mon Dec 31, 2012 6:07 pm
post ffmpeg -i of the mkv files that are affected. And what profile are you using?
texwatson
Post Sat Jan 05, 2013 4:16 pm
Hi, thanks for your reply. Sorry, I'm a newbie to this. I've tried a ffmpeg -i on the file name, but it's asking for a valid output file. Could you help me with the command you want me to post, I've several video examples where the aspect isn't right using the Panasonic 2012 profile.
Thanks again.
Post Sat Jan 05, 2013 7:56 pm
texwatson
Post Sun Jan 06, 2013 8:26 pm
Here's some that the aspect ratio 'expanded' to fill the screen, stretching the video.
C:\Program Files\Serviio\lib>ffmpeg -i "c:\users\lee\videos\Harry.Potter.Complet
e.1080p.Bluray\Harry.Potter.And.The.Chamber.Of.Secrets.2002.1080p.Bluray.x264.an
oXmous\Harry.Potter.COS.mp4"
g-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'c:\users\lee\videos\Harry.Potter.Comple
te.1080p.Bluray\Harry.Potter.And.The.Chamber.Of.Secrets.2002.1080p.Bluray.x264.a
noXmous\Harry.Potter.COS.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isom
Duration: 02:40:56.25, start: 0.000000, bitrate: 1867 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x800
[SAR 1:1 DAR 12:5], 1779 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
handler_name : GPAC ISO Video Handler
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 83
kb/s
handler_name : GPAC ISO Audio Handler
Another:
C:\Program Files\Serviio\lib>ffmpeg -i "c:\users\lee\videos\Jaws.1975.1080p.mkv"
g-config
Input #0, matroska,webm, from 'c:\users\lee\videos\Jaws.1975.1080p.mkv':
Duration: 02:03:54.63, start: 0.000000, bitrate: 10097 kb/s
Chapter #0.0: start 0.000000, end 108.900000
title : 00:00:00.000
Chapter #0.1: start 108.900000, end 453.787000
title : 00:01:48.900
Chapter #0.2: start 453.787000, end 680.179000
title : 00:07:33.787
Chapter #0.3: start 680.179000, end 815.356000
title : 00:11:20.179
Chapter #0.4: start 815.356000, end 1091.590000
title : 00:13:35.356
Chapter #0.5: start 1091.590000, end 1470.260000
title : 00:18:11.590
Chapter #0.6: start 1470.260000, end 1661.243000
title : 00:24:30.260
Chapter #0.7: start 1661.243000, end 1966.673000
title : 00:27:41.243
Chapter #0.8: start 1966.673000, end 2718.007000
title : 00:32:46.673
Chapter #0.9: start 2718.007000, end 3211.041000
title : 00:45:18.007
Chapter #0.10: start 3211.041000, end 3688.643000
title : 00:53:31.041
Chapter #0.11: start 3688.643000, end 3971.801000
title : 01:01:28.643
Chapter #0.12: start 3971.801000, end 4863.192000
title : 01:06:11.801
Chapter #0.13: start 4863.192000, end 5184.971000
title : 01:21:03.192
Chapter #0.14: start 5184.971000, end 5784.237000
title : 01:26:24.971
Chapter #0.15: start 5784.237000, end 6600.803000
title : 01:36:24.237
Chapter #0.16: start 6600.803000, end 7007.167000
title : 01:50:00.803
Chapter #0.17: start 7007.167000, end 7072.357000
title : 01:56:47.167
Chapter #0.18: start 7072.357000, end 7355.640000
title : 01:57:52.357
Chapter #0.19: start 7355.640000, end 7434.635000
title : 02:02:35.640
Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x816, SAR 1:1 DAR 40:17,
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s (def
ault)
Stream #0:2(eng): Subtitle: text
For me to fix this, I had to 'hack' the Panasonic Profile to this:
<Profile id="4" name="Panasonic Viera 2012" extendsProfileId="1">
<!-- Panasonic Viera G30, GT30, DT30, UT30 With avi (2011), xx50 (2012) With AVI Support -->
<Detection>
<UPnPSearch>
<FriendlyName>(VIERA (G|D|U)T?(3|5)0?.*)|(VIERA VT50.*)</FriendlyName>
<Manufacturer>Panasonic</Manufacturer>
</UPnPSearch>
</Detection>
<MediaFormatProfiles>
</MediaFormatProfiles>
Return to Panasonic
