raw images not working
azar
Post Wed Dec 26, 2012 6:27 pm
I have been looking forward to serviio handling raw images but it does not seem to be working for me - I get the thumbnails but when I select a pic to view it says the file is not supported. I have a UE46ES8000 smart tv.
I have switched on debugging (file attached) and it seems to run dcraw ok but fails with an i/o error.
Do you have any suggestions?
serviio.log.rar
log file
(22.96 KiB) Downloaded 427 times
GoodStuff
Post Thu Dec 27, 2012 10:15 am
Re: raw images not working
Same here on my LE32D550, thumbnails display correct.
azar
Post Thu Dec 27, 2012 2:50 pm
The file is transcoded using JPEG_LRG
2012-12-26 17:37:03,643 DEBUG [ImageDeliveryEngine] Retrieving transcoded version of file CRW_6606.CRW using format profile JPEG_LRG
However, the TV's standard suggests it only handles JPEG_MED and JPEG_SM.
Could this be the problem? And if so how do you change this setting?
REG40136858.pdf
Certification details
(124.49 KiB) Downloaded 402 times
aleph
Post Thu Dec 27, 2012 8:17 pm
my tv and blu-ray http://certification.dlna.org/certs/REG13435082.pdf and http://certification.dlna.org/certs/REG08136087.pdf support JPEG_LRG but also don't display canon raw files
so may be problem in something else
Post Fri Dec 28, 2012 12:37 am
Can you confirm if it works with PS3 Media Server?
azar
Post Fri Dec 28, 2012 7:26 am
I don't have a PS3 player so can't confirm.
I've tried the android app serviigo and that works a treat so it's definitely something to do with the tv and how it handles the converted file.
aleph, do you have a ps3? Can you confirm?
aleph
Post Fri Dec 28, 2012 1:35 pm
the question was about ps3 media server http://www.ps3mediaserver.org/ you can setup it yourself and try.
raw images transcoding does not seem to work with current version of ps3 media server http://www.ps3mediaserver.org/forum/vie ... =6&t=14894
folders with cr2/crw files empty and I don't see much options to configure related to images file format or anything similar.
azar
Post Sat Dec 29, 2012 3:02 pm
OK, so I downloaded v1.7 that didn't work - it is broken wrt to RAW images. So I downloaded 1.6 and got it to work.
I have attached the debug.log file if that helps...
I hope you can set this sorted :)
debug.log
(21.14 KiB) Downloaded 481 times
azar
Post Thu Jan 03, 2013 10:34 pm
Hi zip,
I appreciate you have lots of things in your to-do list.
If there is anything I can do by providing more information or doing some of the leg work please let me know.
Cheers
Post Fri Jan 04, 2013 11:11 am
I wanted to do this, but if you're free it'd help:
1) Install PMS, share a foled with a single RAW image
2) run Wireshark and filter traffic between the TV/Player and the PC
3) browse to the image in PMS and display it
4) save the captured packets
Then do the same with Serviio.
I'll have to compare the HTTP headers and protocol differences between these two.
aleph
Post Wed Jan 09, 2013 11:06 am
hi
here dump from serviio and from pms
(pms was set up without thumbnails and serviio show thumbnail)
forum restrictions don't permit files above 500KiB
so I shared them via dropbox https://dl.dropbox.com/u/33248417/serviio/pms_only.gz and https://dl.dropbox.com/u/33248417/servi ... io_only.gz you should be able to download them freely
p.s. zip please tell me, when you download this files, so I can delete them
Post Thu Jan 10, 2013 5:51 pm
Thanks, got the files.
