DTV HR34
solcare435
Post Sat Dec 29, 2012 12:13 am
DTV HR34
I have a DTV HR34 and HR24. The HR24 works fine with Serviio 1.1 but when I use the media share with the HR34 it works fine also but after I watch a movie the profile for DirevTV HD-DVR in Serviio switches back to Generic DLNA profile and then I have a X next to the movie title in my media share. Then I go back to the Serviio and change the profile back to DirecTV HD-DVR and save it and works fine. I read some threads about the HR24 having the same issue back then and was fixed. So my question is, is there a fix for this issue on the HR34?
Thanks,
Post Sat Dec 29, 2012 12:45 pm
Re: DTV HR34
Did you set up static IP for the device?
solcare435
Post Sat Dec 29, 2012 6:46 pm
Re: DTV HR34
My HR34 is static.
Post Mon Dec 31, 2012 6:19 pm
Re: DTV HR34
can you post detailed log when this happens?
solcare435
Post Tue Jan 01, 2013 10:33 pm
Re: DTV HR34
Here wo go:
2013-01-01 16:04:34,937 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-01-01 16:04:34,937 INFO [WebServer] WebServer shutting down
2013-01-01 16:04:34,955 INFO [EventDispatcher] Leaving EventDispatcher
2013-01-01 16:04:34,970 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-01-01 16:04:34,970 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-01-01 16:04:35,235 INFO [WebServer] WebServer starting on port 8895
2013-01-01 16:04:35,235 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-01 16:04:35,235 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-01 16:04:35,267 INFO [EventDispatcher] Starting EventDispatcher
2013-01-01 16:04:35,268 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.114, timeout = 0
2013-01-01 16:04:35,549 INFO [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-01 16:12:28,611 INFO [WebServer] WebServer shutting down
2013-01-01 16:12:28,611 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-01-01 16:12:28,611 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-01-01 16:12:28,611 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-01-01 16:12:28,611 INFO [EventDispatcher] Leaving EventDispatcher
2013-01-01 16:12:28,939 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-01 16:12:28,939 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-01 16:12:28,939 INFO [WebServer] WebServer starting on port 8895
2013-01-01 16:12:28,939 INFO [EventDispatcher] Starting EventDispatcher
2013-01-01 16:12:28,989 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.114, timeout = 0
2013-01-01 16:12:29,402 INFO [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-01 16:12:29,402 INFO [RendererManager] Stored a new renderer: uuid='66416c54-9c83-42d2-a9a7-5c97557f2d7c', name = 'DirecTV HD-DVR', ipAddress='192.168.1.121', profile = '6'
2013-01-01 16:28:25,282 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-01-01 16:28:25,284 INFO [WebServer] WebServer shutting down
2013-01-01 16:28:25,284 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-01-01 16:28:25,284 INFO [EventDispatcher] Leaving EventDispatcher
2013-01-01 16:28:25,284 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-01-01 16:28:25,580 INFO [WebServer] WebServer starting on port 8895
2013-01-01 16:28:25,580 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-01 16:28:25,580 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-01 16:28:25,580 INFO [EventDispatcher] Starting EventDispatcher
2013-01-01 16:28:25,617 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.114, timeout = 0
2013-01-01 16:28:25,872 INFO [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
Post Wed Jan 02, 2013 11:22 am
Re: DTV HR34
First, it's not detailed log, see my signature on how to set it up
Second, did you restart the server a couple of times (with the buttons in the console)?
I'll need a 10 minute detailed log without you touching anything in the console.
solcare435
Post Thu Jan 03, 2013 9:05 am
Re: DTV HR34
I attached the log, the HR34 with problems is the 192.168.1.121
Serviio_HR34 Log.txt
(337.61 KiB) Downloaded 466 times
solcare435
Post Fri Jan 11, 2013 11:24 pm
Re: DTV HR34
Any takers on this log?
Users browsing this forum: Google [Bot] and 30 guests
