convert PS3 MS config file -> serviio config (Philips NetTV
bassie127
Post Mon Dec 27, 2010 9:13 am
Hi all,
I'm new to Serviio. I have have tried PS3 media server before with my Philips NetTV type 9604. This works, but the processor load is very high.
I would like to give Serviio a try.
I would like to create a new Serviio profile for my TV, because I cannot play all formats with the profiles already present. Especially
o "H264 - mpeg-4 avc (avc1) video with mpeg aac (mp4a) audio" and
o wmv files with WMV3 video and WMA2 audio
don't play (no video no audio).
I have added a new profile, but I've some problems getting the right info in it.
I do however have a config file for the PS3 media server that works.
Can anybody help me with converting this PS3 config file to a servioo config file?
The PS3 config file is below
Any help is welcome!
# ps3mediaserver renderer profile for Philips Aurea TV and Net TV
# Refer to PS3.conf for help
# The protocol string is (for mpeg2) :
# http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL
# General informations / detection # General informations / detection
# Added Aurea.png to ps3.jar with winrar
RendererName=Philips Aurea TV NetTV
# UserAgent: regular expression to detect the connected renderer
# Renderer name string: Allegro-Software-WebClient/4.61 DLNADOC/1.00
UserAgentSearch= Allegro-Software-WebClient
# Basic capabilities
Video=true
Audio=true
Image=true
## DLNA settings
##Use the DLNA feature seek by time and not by range
# SeekByTime=true
SeekByTime=false
## Transcoding/Muxing capabilities
##Transcode codecs for video and audio engines #
##currently supported: MPEGAC3 or WMV for video, PCM or MP3 for audio
TranscodeVideo=MPEGAC3
TranscodeAudio=PCM
## TranscodeAudio=MP3
##Use default DVD buffer size: false = greater bitrate and faster encoding,
##but can generate incompatible videos, depends of your media renderer
##DefaultVBVBufSize=false
DefaultVBVBufSize=true
##Muxing capabilities: Does the media renderer supports H264 and MPEG2 in a mpegts file ?
## MuxH264ToMpegTS=true
MuxH264ToMpegTS=false
##Does the media renderer supports DTS in a mpeg file ?
# MuxDTSToMpeg=false
MuxDTSToMpeg=true
##Does the media renderer supports DTS wrapped into LPCM in a mpeg file ?
# WrapDTSIntoPCM=true
WrapDTSIntoPCM=false
##Does the media renderer supports LPCM in a mpeg file ?
MuxLPCMToMpeg=true
## MuxLPCMToMpeg=false
##Maximum bitrate supported by the media renderer (0=unlimited)
MaxVideoBitrateMbps=0
##Max Width and Height supported by the media renderer (0=unlimited)
MaxVideoWidth=1920
MaxVideoHeight=1080
##Does the media renderer supports only H264 L4.1 at most ?
## H264Level41Limited=true
#Does music files need to be resampled at 44.1kHz?
TranscodeAudioTo441kHz=false
#Does the client need to receive transcoded video with minimal delay ? (Useful when the client has a small timeout delay)
TranscodeFastStart=true
#Size of the transcoded file (unknown length) sent to the renderer (could determine browsing failure/success)
#Possible values:
# -1: Specific value working with the PS3, means perfect transcoding and copying support (it's against the dlna spec though)
# 0: size attribute is NOT sent to the renderer (defaut value if this parameter isn't used)
# 100000000000: 100Gb, if you want to be sure that the media file is not cutted before the end ?
TranscodedVideoFileSize=100000000000
## Misc Files
## If you want to apply a specific extension for your transcoded files:
# UseSameExtension=mpg
## Mime types transforms (oldmime=newmime|olemime2=newmime2|…)
# MimeTypeChanges=video/avi=video/x-divx
# MimeTypesChanges=video/mp4=video/mpeg
## Extensions management: no need to put something here, as the server's default configuration is tuned for ps3
## What extensions are forcefully streamed as is (and not transcoded)
StreamExtensions=
## What extensions are forcefully transcoded
# Needed for Philips Aurea that can only handle mpg, mp3
# Not needed for Philips NetTV that can handle many formats natively *****I have a NetTV****
TranscodeExtensions=avi,wmv,mkv,wmv,ts,m2ts,tp,iso,mp4,mov
Post Mon Dec 27, 2010 9:36 am
Re: convert PS3 MS config file -> serviio config (Philips NetTV
Please provide the GetProtocolInfo sink result: viewtopic.php?f=5&t=19
We will help you...
