How to customize navigation tree (presentation) ?
welverin
Post Sat Dec 29, 2012 8:12 pm
Hi, i love this software, i just installed v. 1.1 and i find it very good
Now i want customize the file tree i see in my tv when open dlna connection to serviio
More detailed i want to see:
Server -> folder1
.......... Folder2
.......... Folder3
......... Folder4
Where fonder 1 contain only audio files and folder 2,3,4 contain only video files
Is it possible? I thing something like xml file editing ?
Thank you all and happy new year!
Leonardo
Philips 2010 7605
Serviio 1.4 on QNAP NAS 239 Pro II Fw 4.1
Xmantium
Post Sun Dec 30, 2012 2:33 am
Re: How to customize navigation tree (presentation) ?
Navigation tree with XML, you must be originally a Twonky user. So was I until I found Serviio.
You choose the types of files when you add the folder, only tick the audio box for your folder one, and only video fr your other video folders
There's some inctructions here - http://www.serviio.org/component/conten ... ng-started
welverin
Post Sun Dec 30, 2012 8:07 am
in the presentation tab i can choose for every category "display content only", disable all but "folders" = display content only
and i load in the library father folder of multimedia files
i use qnap too, so i load /share/Multimedia
now when i navigate dlna tree i see two folder multimedia, with the same list o folder inside
in the first multimedia folder all folder are empty but the folder contain mp3 files, in the second multimedia folder the opposite
any idea ?
Philips 2010 7605
Xmantium
Post Sun Dec 30, 2012 12:03 pm
Alright, see what you mean, i share each folder separately ie
share/Qmultimedia/Folder 1
share/Qmultimedia/Folder 2
So just don't put the whole root folder. This way I can organise what appears first.
welverin
Post Sun Dec 30, 2012 4:18 pm
done !
it works now
thank you very much !
Philips 2010 7605
Users browsing this forum: Baidu [Spider] and 92 guests
