[SOLVED] Serviio Console Remote
Filip87
Post Sat Dec 29, 2012 12:24 pm
Hi all,
first of all sorry for my english, i havn't used it for a quiet long time.
Now to my problem: I run an Ubuntu 12.04 server on which i installed Servio Server as discribed in your wiki. That was quiet easy.
Afterwards i installed Servio Console on my Windows8 x64 PC and added -Dserviio.remoteHost=10.192.43.16 to ServioConsole.exe.vmoptions.
When i try to start the ServioConsole.exe nothing happens.
The log says:
2012-12-28 23:09:15,563 INFO [ServiioConsole] Starting Serviio Console
2012-12-28 23:09:15,642 INFO [ServiioConsole] Connecting to Serviio REST on 10.192.43.16:23423
2012-12-28 23:09:16,283 INFO [Messages] Loaded console message bundle for locale: en
2012-12-28 23:09:18,596 ERROR [ServiioConsole] Unexpected exception occured: null
at org.serviio.ui.view.swing.PresentationView.initComponents(PresentationView.java:92)
at org.serviio.ui.view.swing.PresentationView.<init>(PresentationView.java:81)
at org.serviio.ui.view.swing.ServiioFrameView.<init>(ServiioFrameView.java:79)
at org.serviio.console.ServiioConsole.main(ServiioConsole.java:106)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2012-12-28 23:09:18,596 INFO [ServiioConsole] Leaving Serviio Console
In the Server there is no connect visible in the log.
Downgrading from Java7 to Java6 on the client and reinstalling ServiioConsole didn't help.
Any idea?
Greetz Filip
Post Sat Dec 29, 2012 12:34 pm
Re: Serviio Console Remote
This looks like incompatible versions of the server and console. Are they both 1.1? It's possible the wiki article is not up to date.
Filip87
Post Sat Dec 29, 2012 2:16 pm
Okay, seems that was the problem.
Unfortunately I don't have a wikiaccount. Someone should correct the download link!
Xmantium
Post Sun Dec 30, 2012 2:36 am
Yes the version in the wiki page is the old v1.0.1
You can also try ServiiDroid if you have an Android or ServiiWP for Windows phone, it supports various versions of Serviio
