DMP-BDT220 canot play mp4 or mkv via serviio
computerguy7
Post Thu Dec 27, 2012 1:43 am
I have numerous home video files that use the AVCHD codec from my panasonic camcorder. They play fine via serviio to Panasonic TV (TC-L47E5) or Panasonic Bluray (DMP-BDT220).
My mp4 and mkv (h264 codec made by handbrake) only play on the TV, but not the bluray. I think the bluray must not support natively and therefore requires transcoding. Twonky plays both file types fine via DLNA, but serviio does not. Any suggestions?
- I tried tweaking profiles.xml, but I do not know what to try.
- I tried copying some new panasonic profiles from the serviio forums, but they also do not work.
error says, "cannot play file"
- since twonky can play file I think it is just a config issue on serviio, help please.
thanks for the help in advance.
computerguy7
Post Thu Dec 27, 2012 2:46 am
Re: DMP-BDT220 canot play mp4 or mkv via serviio
update
in the forums I found this which did not work
<Profile id="24" name="Panasonic Viera With AVI Support" extendsProfileId="1">
<MediaFormatProfiles>
</MediaFormatProfiles>
<!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="20000">
<Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
<Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
<Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
<Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
<!-- remux VORBIS/FLAC/LPCM in MKV/MP4 to AC3 -->
<Video targetContainer="mpegts" targetACodec="ac3" >
<Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
<Matches container="mp4" vCodec="h264" aCodec="aac"/>
<!-- Remux MPEG-TS with no transcoding -->
<Matches container="matroska" vCodec="mpeg2video"/>
<!-- Remux WTV files to MPEG-PS with no transcoding-->
<Matches container="wtv" />
<!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
<Matches container="mp4" vCodec="mpeg4" />
<Matches container="mpeg" vCodec="mpeg1video" />
<Matches container="matroska" vCodec="mpeg4" />
<Matches container="asf" />
<Matches container="flv" />
<Matches container="ogg" />
<Matches container="3gp" />
<!-- unsupported audio will be transcoded into lpcm audio -->
<Matches container="flac" />
<Matches container="adts" />
</Audio>
I changed it to this and now the files play, but pause, fast forward, and rewind do not behave as expected. The video freezes.
<Profile id="25" name="Panasonic Viera With AVI Support" extendsProfileId="1">
</Audio>
why did what I did help? Can I get FF and RW working or should I just be happy?
computerguy7
Post Fri Dec 28, 2012 7:14 pm
i also noticed the hulu plugin works on my tv but not on my bluray player. my tv must support more codecs variations
Post Sun Dec 30, 2012 2:56 am
I had a BDT-220, but returned it because its DLNA functionality was no better than the -110 I already had. I've switched to the Sony SNP-N200 for most of my streaming, but unfortunately Sony discontinued it for a much more expensive box. The Sony seems to play just about everything I throw at it, including some ripped Blu-rays with Dolby TrueHD audio. It doesn't seem to support DTS Master Audio however. Have to stick with the standard DTS audio track.
computerguy7
Post Mon Dec 31, 2012 1:04 am
I guess I get what I pay for. Do you suggest a better bluray player now?
Post Mon Dec 31, 2012 1:38 pm
computerguy7 wrote:I guess I get what I pay for. Do you suggest a better bluray player now?
As far as being a BD player, the 220 is outstanding. Its DLNA functionality isn't perfect, but does fairly well. I have no experience with any other players, but I have heard good things about Samsung.
computerguy7
Post Mon Dec 31, 2012 4:13 pm
Have you found any xml profiles that work best with the BDT220?
Post Tue Jan 01, 2013 11:30 pm
computerguy7 wrote:Have you found any xml profiles that work best with the BDT220?
Since I no longer have it, I can't say for sure. I believe I was using the Panasonic Viera 2011 profile, but can't remember for certain.
KrisDech
Post Sat Jan 26, 2013 5:15 pm
You might want to check this thread for my BDT220 profile:
viewtopic.php?f=13&t=5983
Return to Panasonic
