audio not supported and random drop outs
kevinm2k
Post Sun Dec 30, 2012 3:17 pm
Hi. I use futubox with serviio to stream to my smart TV.
It does work but I have not yet once been able to watch something without problems. A lot of the time I get audio not supported whilst watching, after a bit this will resolve itself and continue but it happens frequently. I also get cut outs where it says the service is no longer available and closes. Other times the video and audio are very choppy.
The TV I have is recognised in serviio and it is a Samsung series e.
I have upgraded to 1.1 but still no better I can go a maximum of about 15 minutes before the errors start.
Does anyone have any suggestions?
Kevin
Post Mon Dec 31, 2012 2:14 pm
Re: audio not supported and random drop outs
Are these transcoded files? (check detailed log). If not it might be due to a slow IO/network, if it transcodes a slow CPU might cause this.
kevinm2k
Post Tue Jan 01, 2013 12:17 pm
Hi Zip,
Thanks for replying.
Can I ask where the detailed logs are so I can have a look? Would it better to turn off transcoding? I do only have a dual core system - quite old but thought it would be fast enough.
It is over a wifi network not wired but again it is a virgin super hub which I would hope would be fast enough.
Post Tue Jan 01, 2013 9:23 pm
Try disabling transscoding to make sure. Wifi connection might also be a problem, depends on the quality of the signal and distance from the router.
kevinm2k
Post Sat Jan 05, 2013 10:57 am
To be honest it seems a little worse without transcoding on. The virgin WiFi router is about 3 yards from TV. But is via WiFi not Ethernet.
Are there any logs that might tell me what the problem is?
Post Sat Jan 05, 2013 1:31 pm
If it's this close, try it with wired connection.
kevinm2k
Post Mon Jan 14, 2013 4:51 pm
I'll try and get hold of another Ethernet cable and try it out. I have a couple of home plugs hanging around as well. Just read something about turning off windows media network streaming service so I'll give that a go and see if that improves anything
Sent from my Nexus 4 using Tapatalk 2
