serviidb.com
Post Thu Dec 27, 2012 4:44 pm
Re: serviidb.com
I converted my site to run under mbm-worker instead of mbm-prefork so the memory usage is better controlled and should make the site more reliable. By doing this I lowered average memory use on the VPS by 300 Meg.
Post Sat Dec 29, 2012 6:20 pm
Re: serviidb.com
Can one of the UI developers run a test using the http://serviidb.com/apidev/video response and make sure I did not change anything by mistake. I tweaked the SQL to make it pull unique media from the database
Xmantium
Post Mon Dec 31, 2012 1:36 pm
Re: serviidb.com
Hi moltra thanks for updating some of the plugin contents! we now have plugin versions! :)
UI devs, can you please include plugin description, plugin version, plugin logo - 200px max, plugin working status
Few things,
Plugin Tyle: should be Plugin Title:
The tables on the homepage seem to not work, every content i add seems to put in no plugin table, but the api content is working fine
when you moved the "The Verge" Youtube content it seems to have dissapeared. So it seems the site api is working but the tables are not accurate
I created a new plugin content, Billboard Top20, but this is not showing up on the dropdown list
edit:
Ive added a few ITV entries for the new plugin, the api works fine to view these, but when i want to edit this on the website, it shows it has no values, could be the reason why its all showing in the non plugins folder
Post Mon Dec 31, 2012 4:52 pm
Re: serviidb.com
Xmantium wrote:Hi moltra thanks for updating some of the plugin contents! we now have plugin versions! :)
Few things,
edit:
I have to add the new information to the API plugin response.
Plugin Tyle was actually Plugin Type. Fixed
The reason the new entries was not showing up on the front page was that the Required Plugin field was not filled in. I filled it in and they are showing up on the front page now. I am going to make it default to "None" if the field is not filled in. That was it will be easy to find.
In the Required Plugin field you can add it right in the Box, just type the name and it will create the taxonomy term (what allows the site to show all media content for a plugin).
Check the ITV entries they look good to me.
I think I removed the Verge content since almost everything was blank, sorry.
Post Mon Dec 31, 2012 5:12 pm
Re: serviidb.com
moltra wrote:Can one of the UI developers run a test using the http://serviidb.com/apidev/video response and make sure I did not change anything by mistake. I tweaked the SQL to make it pull unique media from the database
Seams to be working fine.
Post Mon Dec 31, 2012 5:18 pm
Re: serviidb.com
I have already changed the production /api to the new SQL. Also, I will be adding new content to the plugin API today or the next day or two.
Xmantium
Post Mon Dec 31, 2012 6:23 pm
Re: serviidb.com
serviiDB is shaping up very nicely! :D
When the plugin api link to serviDB it will be awesome!
Is Plugin Type the same as Plugin API name?
When i searched items for ITV Player, in ServiiDroid it thinks ive not got the plugin installed as the API name is "ITVPlayer (UK only)", in here its "ITV Player (UK)"
Also Mark can you change the description and site url fields in http://www.serviidb.com/node/add/media to plain text
with "Plugin Status" - are there going to be more options?
Post Mon Dec 31, 2012 7:02 pm
Re: serviidb.com
Xmantium wrote:Hi Mark, I think plugins need a overhaul revamp.
It should contain these values. Please let me you think.
Plugin Type: Choice of TV, Live TV, Sports, Misc, Music, Adult... can think of anymore for now
I thought I changed that, I will change it today.
Yes I can add more options. Any that you want me to add?
Xmantium
Post Mon Dec 31, 2012 7:29 pm
Re: serviidb.com
Ah! Gotcha!
Plugin API Name - Definately important one
Plugin Intructions: so new users don't need to read through forums to learn about extra parameters URLs can use
Plugin Forum link: user can quickly view the forum link of the groovy post
Post Mon Dec 31, 2012 8:24 pm
Re: serviidb.com
Added two of the fields and renamed one existing field.
also changed the media required plugin to select only field.
Post Mon Dec 31, 2012 8:38 pm
Re: serviidb.com
Let me know if you guys want a different order of the fields. I am trying to clean up the UI a little bit.
Post Tue Jan 01, 2013 8:56 am
Re: serviidb.com
Searching via ServiiDroid, the UK content (BBC iPlayer, 4oD, ITV Player) is missing, any idea why?
Post Tue Jan 01, 2013 9:26 am
Re: serviidb.com
will wrote:Searching via ServiiDroid, the UK content (BBC iPlayer, 4oD, ITV Player) is missing, any idea why?
No the data is there, just for some reason mysql is not returning it.
Post Tue Jan 01, 2013 10:08 am
Re: serviidb.com
I tried reverting to a backup from 8 hours ago, but still not showing UK content. I am currently running a complete database check and repair. I will look at it in the morning, it is 5 AM here and I have been up all night.
Sorry about the problems with the database.
Post Tue Jan 01, 2013 5:31 pm
Re: serviidb.com
I removed all searches but the title/plugin so everything is showing up again. Will look at it when i get home.
Post Tue Jan 01, 2013 5:58 pm
Re: serviidb.com
All searches back enabled except for plugin.
Xmantium
Post Tue Jan 01, 2013 7:15 pm
Re: serviidb.com
all searches working fine now, those plugins didnt have a "plugin name" attached to it
Mark we should create a separate item for "Plugin API" solely to match the plugin api name, when we change the plugin name to the api name - the search breaks
Post Sat Jan 05, 2013 5:08 pm
Re: serviidb.com
serviidb.com is currently down as I am applying patches to the OS. Should be back up shortly.
Post Sat Jan 05, 2013 5:35 pm
Re: serviidb.com
serviidb.com is back up. I just completed a major OS upgrade so there might be a few bugs, If you find any let me know so I can fix them.
Post Sun Jan 06, 2013 1:11 am
Re: serviidb.com
I just performed a server OS update and I am currently having file permission problems with the demonstration Media server. I am working to get it resolved as fast as possible.
