[SOLVED] No sound on Sony Bravia 2012 online streams
moose7
Post Mon Dec 31, 2012 5:26 pm
I had no sound in some streams with Serviio 1.1 and Sony Bravia 2012.
To find the cause I did the test:
ffmpeg -i "rtmp://46.105.112.212:1935/live Playpath=mpegts.stream swfUrl=http://www.eska.tv/thrdparty/flowplayer/flowplayer.rtmp-3.1.4.swf pageUrl=http://www.eska.tv/player tcUrl=rtmp://46.105.112.212:1935/live swfVfy=1 live=1"
ffmpeg -i output shows:
Stream #0:0: Video: h264 (Main), yuv420p, 480x288 [SAR 1:1 DAR 5:3], 563 kb/s, 25 tbr, 1k tbn, 50 tbc
Stream #0:1: Audio: mp3, 44100 Hz, stereo, s16p, 192 kb/s
Seems I got problem with mp3 audio stream.
To solve this problem I had to add aCodec="aac" to the <Matches container="flv" vCodec="h264" aCodec="aac" /> under Sony Bravia TV (2012) profile in <OnlineTranscoding> section.
<OnlineTranscoding>
   <Video targetContainer="mpegts" forceInheritance="true"> <!-- do not transcode to ac3 -->
      <Matches container="mp4" />
      <Matches container="applehttp" vCodec="h264" />
   <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
      <Matches container="asf" /> <!-- to support mms:// streams -->
      <Matches container="flv" />
</OnlineTranscoding>
Finally the sound came on after this modification of profiles.xml. :)
steve11
Post Wed Jan 02, 2013 4:04 pm
Re: [Solved] No sound on Sony Bravia 2012 online streams
Super, is also working on my 2011!!!!
Very Thanks
Steve
moose7
Post Wed Jan 02, 2013 6:42 pm
You are welcome.
Seems there is another solution how to fix sound problem, but if you modify the same line with contentType="vod" insted of adding aCodec="aac"
in some streams you will get distorted picture format. For instance instead 16:9 I got 4:3.
like this:
<Matches container="flv" vCodec="h264" contentType="vod" />
Original source: Re: No Sound on Sony KDL-40ex723 online streams by newborn
steve11
Post Wed Jan 02, 2013 9:53 pm
Thanks moose7!
Steve
newborn
Post Tue Jan 08, 2013 7:30 pm
Interesting, I wonder which is the more correct fix... Zip didn't notice the other thread before it disappeared.
newborn
Post Sat Mar 02, 2013 5:34 pm
How can we get these changes moved into 1.3 ? I lost them all on upgrade to 1.2 and lost sound on online streams again.
Post Sat Mar 02, 2013 5:39 pm
newborn wrote:I lost them all on upgrade to 1.2 and lost sound on online streams again.
Your previous profile had to be saved profiles.bak
newborn
Post Sat Mar 02, 2013 5:48 pm
That's cool thanks. I've put in the fix from the first post rather than the change I was using, and I think its probably better. Can we get the change into Serviio 1.3?
Users browsing this forum: Google [Bot] and 6 guests
