Toshiba REGZA 37UL863
xXsamXx1991
Post Tue Dec 25, 2012 1:53 pm
I have a Toshiba REGZA 37UL863.
This is what i get with device spy:
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T,
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED
I have got 2 dlna-servers, the first is allshare and the second is the wmp, but i want to use only one dlna-server on my linux-server and so i have found serviio.
The problem is that the movies work fine on this tv with the windows media player 12 and shark007codec pack.
But with serviio (profile: Thoshiba REGZA), the mkv randomly stops while watching and in avi the sound is deformed.
Also the pause/play/forward/backward-function doesn't work.
Can anybody help me to find the failure in the profile?
xXsamXx1991
Player: Samsung UE46C5700 | Server: Ubuntu 14.04 LTS
Player: Samsung UE40F5370
Player: Toshiba REGZA 37UL863
Intel UPnP tools | HOWTO: Turn on detailed logging | HowTo: Provide supported formats of a device | HowTo: Provide details of a video file that doesn't play | HowTo: Remove header compression
Post Tue Dec 25, 2012 11:00 pm
Re: Toshiba REGZA 37UL863
Do you have a recent ffmpeg?
xXsamXx1991
Post Wed Dec 26, 2012 4:54 am
I have compiled the newest version of ffmpeg on my linux-server and also i have tried serviio on my win7-pc and on both computers the problem appears.
xXsamXx1991
xXsamXx1991
Post Sat Dec 29, 2012 1:31 pm
Any other advice?
I would also buy pro if this works ;)
xXsamXx1991
Post Mon Dec 31, 2012 6:38 pm
do you have enough space in the transcoding folder?
xXsamXx1991
Post Tue Jan 01, 2013 4:15 am
44,6 GB, I think this is enough.
xXsamXx1991
Post Tue Jan 01, 2013 3:03 pm
Try with this profile.
   <Profile id="13" name="Toshiba REGZA" extendsProfileId="1">
            <Matches container="*" vCodec="h264" />
         <Video targetContainer="mpeg" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="mp4" />
            <Matches container="avi" />
            <Matches container="mpegts" />
            <Matches container="mpegvideo" />
            <Matches container="asf" />
            <Matches container="ogg" />
            <Matches container="flv" />
            <Matches container="3gp" />
            <Matches container="rm" />
            <!-- if audio different to ac3, must be transcoded -->
            <Matches container="mpeg" aCodec="aac" />
            <Matches container="mpeg" aCodec="mp3" />
            <Matches container="mpeg" aCodec="dca" />
         <Audio targetContainer="mp3">
               <Matches container="flac" />
            </Audio>
      <OnlineTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3">
      </OnlineTranscoding>
If you're still having problems post ffmpeg -i for the problematic files.
xXsamXx1991
Post Wed Jan 02, 2013 2:35 pm
The pause/play/forward/backward-function works in avi but in mkv it still does not work.
Also the problem with the sound in this avi still appears:
ffmpeg version git-2012-12-10-a933698 Copyright (c) 2000-2012 the FFmpeg developers
  built on Dec 10 2012 04:17:29 with gcc 4.6 (SUSE Linux)
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
  libavutil      52. 12.100 / 52. 12.100
  libavcodec     54. 79.101 / 54. 79.101
  libavformat    54. 49.100 / 54. 49.100
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 26.101 /  3. 26.101
  libswscale      2.  1.103 /  2.  1.103
  libpostproc    52.  2.100 / 52.  2.100
Input #0, avi, from '3-03 Gold Lecker.avi':
    encoder         : MEncoder dev-SVN-r26940
  Duration: 00:43:22.27, start: 0.000000, bitrate: 1138 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 624x352 [SAR 1:1 DAR 39:22], 25 tbr, 25 tbn, 25 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16p, 32 kb/s
xXsamXx1991
xXsamXx1991
Post Tue Feb 19, 2013 10:01 pm
More ideas or could you tell me, where i can find a manual for the profile creation?
xXsamXx1991
xXsamXx1991
Post Mon Feb 25, 2013 11:29 am
I have resolved my problem with this selfcreated profile:
 <Profile id="19" name="Toshiba Regza (Opt)" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>TOSHIBA REGZA</FriendlyName>
         </UPnPSearch>
      </Detection>
         <!-- Transcode all video to MPEG-PS stream, with MPEG-2 video & AC3 audio -->
      <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="lpcm">
            <Matches container="mpeg" vCodec="h264" />
            <!-- If audio not AC3, it must be transcoded -->
         <!-- Transcode all audio to Linear PCM -->
         <Audio targetContainer="lpcm" aBitrate="192">
            <Matches container="mp3" />
         </Audio>
Now i have the problem with the scale of the movies. I want to change the scale to 1280×720 --> 720p (16:9 PAL/NTSC) HD-Ready.
How could this be done?
xXsamXx1991
Post Tue Feb 26, 2013 6:51 pm
add the DAR attribute, as per docs
xXsamXx1991
Post Tue Feb 26, 2013 7:17 pm
Ah ok so i should use
 <Video targetContainer="mpeg" targetVCodec="mpeg2video" dar="16:9" targetACodec="lpcm">
Is this the only value for this attribute?
xXsamXx1991
xXsamXx1991
Post Sat Mar 02, 2013 2:39 pm
All with this device is working perfect in my opinion with following profile (my LAN is limited in bandwith because i use DLAN):
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
      <Video targetContainer="mpeg" targetVCodec="mpeg2video" maxVBitrate="4000" maxHeight="480" DAR="16:9" targetACodec="lpcm" aBitrate="192">
      <Video targetContainer="mpeg" targetVCodec="mpeg2video" maxVBitrate="4000" maxHeight="480" DAR="16:9" targetACodec="ac3" aBitrate="192">
         </Audio>
      <OnlineTranscoding>
As i mentioned above i bought pro now ;)
xXsamXx1991
xXsamXx1991
Post Mon Aug 19, 2013 10:24 am
After new compiling of ffmpeg for serviio 1.3.1 the problems with the default profile "Toshiba Regza" are corrected.
xXsamXx1991
Return to Toshiba
